It is currently Mon Apr 06, 2026 4:20 am
Reply to topic  [ 9 posts ]
 27 Kohler Low RPMS
Post 27 Kohler Low RPMS
May of this year I bought a 2004 27 Kohler GDLT, let it sit until September and finally picked up a 1844 Go Devil hull for it. When i went to look at the motor it seemed to run fine, fired right up when it was cold and idled/ran fine. He didn't have a tach on the motor though. I threw a tach on and have run the motor a few times the past month. Takes a couple tries to get it to fire and when it does it needs to warm up first or it will die when giving it throttle. Tach reads 1180 at idle, 3080 RPMS in the water and about 3500 out of the water. Boat hits about 14-15mph solo with a cooler and 13 with 3 people and a cooler (Prop is worn and needs to be replaced).
I have run seafoam through the carb and replaced the spark plugs. I don't know a whole lot about motors but I am very comfortable with all other mechanical aspects and would like to try and fix this myself before brining it to the local shop listed on Kohlers website to have them look at it.
Thanks in advance for any help
Thu Oct 06, 2016 5:57 pm
Post Re: 27 Kohler Low RPMS
Start with the cleaning the carb and jets . Could be a few things but gotta start with the basics just to eliminate them
Thu Oct 06, 2016 9:41 pm
Not sure if there is any RPM drop between the SD and LT. MY 27 GDSD runs 4190rpms wot in the water. I have upgraded a few things so that maybe some of the difference but you should be higher than what you are currently in my estimation. Start with cleaning the carb and see what you get from there.
1848 27gdsd
Everyone asks do you know Luke Bryan, I say yes, his music was as shitty in High School as it is now!!
Fri Oct 07, 2016 7:28 am
Turn the governor up to about 4500 out of water.
Fri Oct 07, 2016 7:35 am
Thanks for all the replies. Looks like I'll start with cleaning out the carb/jets and then adjusting the governor this weekend.
Fri Oct 07, 2016 2:38 pm
Tue Oct 18, 2016 10:45 am
Uh, whichever way lets you rev higher. It's not rocket science.
Tue Oct 18, 2016 10:48 am
Tue Oct 18, 2016 11:15 am
Should be in, don't remember.
Tue Oct 18, 2016 11:18 am
