It is currently Sat Apr 11, 2026 2:52 pm
Reply to topic  [ 14 posts ]
 Leak down test results
Post Leak down test results
so after getting my OTC tester in today, I could wait.
followed directions and the eneed up with the following:
Cylinder 1: 17%
Cylinder 2: 5%
With Cylinder 1 the leak are equal parts through intake and exhaust.
With cylinder 2, I'm pretty sure all 5% is exhaust valve.
Any solid opinions on leave alone or not is appreciated.
Tue Oct 18, 2016 7:54 pm
Post Re: Leak down test results
Performance tailing off some?
Tue Oct 18, 2016 8:24 pm
not bad just wanted to see, give some sorta baseline, I have lost about 2-3 mph overall just by myself, with a load only a tad longer holeshot.
Tue Oct 18, 2016 8:32 pm
You can yank the heads off and have a valve job done, just remember that eventually they will start to leak again. So in my opinion it's a "bang for your buck" thing...once you're dissatisfied with performance have them taken care of.
Unless it starts to show symptoms of other problems too.
Tue Oct 18, 2016 8:42 pm
well a few mph in the 2.5 yrs after pulling it out of Daniels yard in Prairieville, I'm still happy, just wanted to know where it's at
Tue Oct 18, 2016 8:45 pm
I had to order one as well, should arrive tomorrow. I've never used one, I figured it should be pretty easy to use
Stock 35gdsd skidding 1654gd
Tue Oct 18, 2016 9:10 pm
that hardest part with the motor completely together is getting the piston TDC
Tue Oct 18, 2016 9:12 pm
Did the piston try to stroke when you applied the pressure?
Tue Oct 18, 2016 9:14 pm
yup lol
Tue Oct 18, 2016 9:24 pm
I think yours might be reading a bit low. When I get a a tight bb Briggs .with no air leaking from valves I'm still in the 10-14 range. If I can hear a little air from valves it's usually north of 20%. My tester is snap on and I know that doesn't mean shit. This one has earned my trust. Maybe someone else will say what there getting
Tue Oct 18, 2016 10:03 pm
Hey Tyler, probably a stupid question but when you did the test did you just take valve covers off?
Wed Oct 19, 2016 11:41 am
Or do you just listen through the exhaust carb and case?
Wed Oct 19, 2016 11:46 am
I left them on
Wed Oct 19, 2016 12:31 pm
What condition is your prop in? Doesn't take much wear on the tips to loose a couple mph on top.
Thu Oct 20, 2016 5:21 am
