It is currently Fri Apr 10, 2026 5:21 am
Reply to topic  [ 18 posts ]
 Dipstick issue
Post Dipstick issue
Ever since I build my engine the dipstick will not stay pushed down into the tube. I constantly have to push it back down during a ride. It only pops out about a half inch, but it still bothers me. Anyone else have this problem? How did you remedy it?
Wed Oct 19, 2016 1:45 pm
Post Re: Dipstick issue
Do a leakdown to find out how much blowby you have on the rings. Shouldn't have that much pressure in there. Add a wrap or two of electrical tape so the dipstick stopper fits tighter if leakdown checks out.
Wed Oct 19, 2016 3:08 pm
Bingo Russ. You have either a worn dipstick (doubt it), but more than likely excessive crankcase pressure. It can be ring blowby or a blown headgasket.
Thu Oct 20, 2016 6:14 am
The dipstick does not fit in the tube as snug with the new case case cover as it did with the old.
I will do a leak down.
The boat runs great though (34 unloaded/32 loaded), so I would think there would be performance issues... not just a dipstick popping out of the tube a half inch.
Thu Oct 20, 2016 6:36 am
GREAT.
I've noticed the same thing recently. Heads were just reworked about 10-15 hours of use ago...
Guess I'm ordering a leak down kit..
Boat runs like a top though.
Kool-Aid Brigade
www.southernfowler.com
Thu Oct 20, 2016 6:37 am
If your rings are leaking I've seen many stock motors have 10-15% leakage from them and run fine. You will have some case pressure its the nature of the beast.
Thu Oct 20, 2016 6:47 am
1. get a piece of string.
2. tie one end of string to big loop on end of dipstick.{where u put your finger at to pull dipstick}
3. tie other end to something else on engine to keep dipstick from popping up.
4. enjoy
Thu Oct 20, 2016 7:16 am
Dead animal.... that is my plan for the time being. I have seen several rigs with their dipstick anchored with wire, string, or zip ties.
Thu Oct 20, 2016 8:33 am
They tend to get pulled out by branches!
Thu Oct 20, 2016 8:48 am
mine would do the same thing, been tied with a string for the last 3700 hours or so. just changed my oil at 3800hrs last week.
Thu Oct 20, 2016 10:14 am
Pinch the tube with pliers to snugg it.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Thu Oct 20, 2016 10:16 am
Has a lot of experience trying to get something that's too small to fit snugly in a hole that's too big. :lol:
Thu Oct 20, 2016 11:25 am
Thu Oct 20, 2016 12:40 pm
A pretty neat tool that I have used is a blow by pressure tester. It will record amount of engine blow by. It will tell u condition of engine. If u search it you can Also build your own simple one. Question for you engine builders will a engine have more blow by at idle or wot.
Thu Oct 20, 2016 7:50 pm
My stocker does it also with 10 hrs on it.
Fri Oct 21, 2016 4:31 pm
Mon Oct 24, 2016 5:31 am
be sure your PCV hose isn't pinched/collapsed/obstructed – trust me on this one :lol:
Tue Oct 25, 2016 10:29 am
My stock 37 did this. Those little small bungee straps work well. Make sure it's a purple one lol
I gave up mud motors
Thu Oct 27, 2016 5:20 am
cron
