It is currently Fri Apr 03, 2026 1:50 pm
Reply to topic  [ 19 posts ]
 Cross threaded bolt on 2015 gatortail 37
Post Cross threaded bolt on 2015 gatortail 37
I cross threaded the grease bolt on my motor. Any suggestions on getting it out.
Fri Oct 28, 2016 3:03 pm
Post Re: Cross threaded bolt on 2015 gatortail 37
Turn it left?
Fri Oct 28, 2016 3:22 pm
Seriously though. Damage is done. Take it out and run a tap thru to clean up the threads. That or throw the shit fuckin thing away.
Fri Oct 28, 2016 3:23 pm
[quote="flint87"]Seriously though. Damage is done. Take it out and run a tap thru to clean up the threads. That or throw the shit fuckin thing away.
Thanks. That's what I was thinking.
Fri Oct 28, 2016 3:35 pm
Fri Oct 28, 2016 4:01 pm
What flint said. The bolt and the hole may be bad . If retapping and cleaning the bolt hole up doesn't work what I usually do is tap the hole the next size larger.
Regardless start with a new bolt if you can
Maybe somebody else has a better idea
Been there done that
Fri Oct 28, 2016 4:13 pm
Easy out?
Fri Oct 28, 2016 4:55 pm
Good pair of vise grip pliers should get it out
Sat Oct 29, 2016 7:28 pm
TORCH THAT BITCH!
Sun Oct 30, 2016 7:28 am
My goodness....
Next question will be how to take the damn grease gun off the grease zerk after pumping grease.
Sun Oct 30, 2016 8:10 am
It's getting bad isn't it :lol:
-Custom pool noodle
-stage 4 water wings
Sun Oct 30, 2016 8:12 am
Sun Oct 30, 2016 8:15 am
X2 on the turn left thing.
why don't u just leave the sombitch like it is?
Sun Oct 30, 2016 12:36 pm
Sun Oct 30, 2016 5:46 pm
Sun Oct 30, 2016 11:39 pm
I never herd them called grease zerks until i came on here, I always called them alemites
Mon Oct 31, 2016 8:19 pm
Got it out. It would not turn. Had to drill it out. I got lucky and I didn't mess up the threads.
I didn't realize I needed a more complex issue to ask for advice.
Thu Nov 03, 2016 7:52 pm
That is a pipe thread plug. Are the threads messed up or just the bolt head rounded off?
Fri Nov 04, 2016 5:54 am
I got it fixed. It is 1/8" pipe thread plug. I crossed it bad and had to drill it out. I used a smaller bit and when it was almost completely drilled it started turning. The threads were damaged but I retapped them and the same size plug fits.
Mon Nov 07, 2016 7:54 am
