It is currently Sun Apr 05, 2026 4:38 am
Reply to topic  [ 23 posts ]
 Coil/1 cylinder vanguard problem
Post Coil/1 cylinder vanguard problem
Got a 35 hp vanguard, the stator was bad so I changed it and while changing the stator and noticed the coils were real rusted and kinda coming apart so I decided to just change them while I was asking taking everything apart, so I changed the flywheel and coils back on, gaped them to 0.05 and it started quick but was running very rough and just not running right so I tested to see they had a spark on the right side and it was very strong spark and that side is fine but the left side has a very week spark and I could tell it's not running right becuase of that side, well I change the plugs and that wasent it, still weak spark, regaped the coil, still weak spark, switched the spark plugs, still nothing, -and changed the connection on the back and checked the ground and still nothing, very clueless here to see what else could be wrong, need help asap
Delta lvl 3 GTR with MAC
16x54 Gator hull
Fri Nov 04, 2016 8:52 pm
Post Re: Coil/1 cylinder vanguard problem
You sure it's getting a good clean not rusted up contact?
Fri Nov 04, 2016 9:00 pm
50 thou. Is too much gap. Any chance new coil is on backwards?
Fri Nov 04, 2016 10:47 pm
Sat Nov 05, 2016 12:45 am
I don't think it's rust becuase I sanded on my flywheel really good to wear it's decently shiny, will sand it more tomorrow to make sure though, and I changed the contact to rule that out for sure, and I'm pretty sure the coil is on the right way because they both say this side out lol
16x54 Gator hull
Sat Nov 05, 2016 1:50 am
Sat Nov 05, 2016 1:54 am
Changing my stator would have anything to do with it huh ?
16x54 Gator hull
Sat Nov 05, 2016 9:02 am
And since I side is getting a good spark and the other side is getting a weak spark, wouldn't that still mean it would be able to run good off of both cylinders since a constant spark is still going on
16x54 Gator hull
Sat Nov 05, 2016 9:20 am
Now it won't even start at all, yesterday it would start and it would just run really rough, now it won't even start at all and it's blowing white blow out carb top and backfiring and when it does that that it gives the motor a very hard jerk
16x54 Gator hull
Sat Nov 05, 2016 9:32 am
Check above^ .... also sure your new coils are same as old,, cdi / non cdi
Sat Nov 05, 2016 10:01 am
Yes the coils are correct for the engine, it is the non CDI engine with th non CDI coils and what do you mean by too much gap ? 0.05 is the recommended
16x54 Gator hull
Sat Nov 05, 2016 10:04 am
Use a business card. 15 ish thou.
Sat Nov 05, 2016 10:25 am
Diode?
Sat Nov 05, 2016 6:29 pm
Regaped them with the business card and still right side has very strong spark, and left side has a very weak spark. Motor will not even turn over now, I checked all the connections and everything seems to be be good and all my grounds are good. Very confused to what it could be now, maybe red wire isn't making good connection anymore cause of rust or something ? Also having some sort of black stuff in my carb
16x54 Gator hull
Sat Nov 05, 2016 10:45 pm
Check battery voltage. How does it turnover by hand with plugs out?. Feel stuck? Also disconnecting your coils will eliminate the poss of a diode. The wire is just to ground coil to turn it off. u will hav to choke it or something else to kill it when testing
Sat Nov 05, 2016 11:17 pm
Any chance it's really flooded
Sat Nov 05, 2016 11:35 pm
mine runs like crap on 1 cylinder from time to time. when it does I get it running and spray a can of cheap wd-40 into the flywheel screen and that usually knocks out my problem until I get it real dirty under there again.
quicker and easier than pulling the shroud and cleaning everything.
sounds like u got a bad diode or connection, and now u are flooded out bad. pull plugs, spin it over a bit and then let it set a while. check all your wires for a bad spot and check grounding.
I use a bidness card to set coils. make sure u don't have a coil upside down.
good luck.
Sun Nov 06, 2016 5:34 am
It was deff flooded, I just pulled the plugs and turned it over for a little bit and gonna let it set for awhile and then spray the flywheel with some wd40 and see what happeneds , all my grounds and connections and are fine, when I try to crank it back up and it's still firing off only 1 cylinder, it would almost be positively the Diodes ? And where are they on the motor ?
16x54 Gator hull
Sun Nov 06, 2016 4:06 pm
Call me. Can't find your number
Sun Nov 06, 2016 5:33 pm
Coil gap on the big block is .005", Also it's a magnetic pulse so rust isn't a detrimental issue.
Mon Nov 07, 2016 6:36 am
The weak spark has been traced to a diode issue. He's going to fix that then go from there.
Mon Nov 07, 2016 1:18 pm
it was the diodes, got some new ones and runs like a champ
16x54 Gator hull
Thu Nov 10, 2016 9:00 pm
Good deal. It's a common issue on non CDI engines
Fri Nov 11, 2016 6:14 am
