It is currently Mon Apr 06, 2026 4:25 am
[ 3 posts ] |
Mounting hydraulic fluid reservoir on prodrive
Exbellicus
Hey installing my new Prodrive...because the transom has a center support beam I am having to relocate the hydraulic fluid piston and reservoir. It says vertical mount only. Does it have to be perfectly straight up in down or can the bottom end lean back in a \ shape?
_________________ 2016 Prodrive X 1848 37efi
| Sun Nov 13, 2016 4:00 pm |
banded-mallard
 Re: Mounting hydraulic fluid reservoir on prodrive
If your talking about the pump itself (motor / reservoir), then yes it can be mounted an a decent angle upright. As long as you have fluid filled above the pickup, it will pump. Its not suggested to put on an angle because it could suck in air and get air in the lines. Hell if it were completely full and no air in the reservoir, you could hold it upside down and it would pump.
| Mon Nov 14, 2016 6:16 am |
Exbellicus
Yup just got off the phone with pro-drive, you are correct
| Mon Nov 14, 2016 8:20 am |
[ 3 posts ] |
