It is currently Fri Apr 10, 2026 9:40 am
Reply to topic  [ 3 posts ]
 Prodrive trim went out. Help!
Post Prodrive trim went out. Help!
Sitting here in the duck blind. Trim went out after running for about 45 minutes. Had something spark where everything hooks up to the motor. Don't know if I blew something. Bad connection or what. When I hit the trim button you can hear it clicking. Any advice would be greatly appreciated.
Is there anyway to manually trim? I can't find any pin to release the hydraulics.
ETA: connection was bad. Back up and running
Sat Nov 26, 2016 5:30 am
Post Re: Prodrive trim went out. Help!
Check connections at the starter on the motor. Check battery connections. Check the back of the trim switch itself. Worse comes to worse
Disconnect hydraulic hoses and limp in with motor trimmed all the way down. That'll make a mess though
Sat Nov 26, 2016 7:50 am
Mon Nov 28, 2016 6:14 am
