It is currently Sat Mar 21, 2026 12:05 pm
Reply to topic  [ 24 posts ]
 Backfire
Post Backfire
35 gatortail with mukuni backfired at full throttle and died. Have cleaned carb changed fuel filter replaced fuel line and plugs. Will not start and continues to backfire while trying to start any suggestions.
Sat Jan 21, 2017 5:46 pm
Post Re: Backfire
Pull valve covers and inspect pushrods n rockers. Could have also popped intake gaskets.. still got good fire?
Sat Jan 21, 2017 6:28 pm
Post Re: Backfire
Or sheared flywheel timing key
PRODRIVE 1860 CC
"Let the good times roll"
Sun Jan 22, 2017 9:18 am
Post Re: Backfire
Sun Jan 22, 2017 10:36 am
Post Re: Backfire
Could be something grounding coils. Mine did the same thing when the oil sensor went out
Sun Jan 22, 2017 1:02 pm
Post Re: Backfire
Yea that's exactly what happens to mine, a key is cheap and pretty easy to fix unless it's really stuck like mine was, but make sure you put a torque wrench on it and I'm pretty sure Briggs says it's 150lbs, I learned the hard way of not doing this
Delta lvl 3 GTR with MAC
16x54 Gator hull
Sun Jan 22, 2017 1:05 pm
Post Re: Backfire
Thank y'all for the help will post what problem is when I get to work on it Tuesday. I felt it was a valve. Brother hit a stup and it happened.
Sun Jan 22, 2017 6:41 pm
Post Re: Backfire
If it happened when u hit a stump,,, then x3 on the timing key
Sun Jan 22, 2017 8:57 pm
Post Re: Backfire
Valve train issues or sheared key in the crank. Both easy repairs but one takes a bit more time. These would be the first two things i'd check.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Jan 23, 2017 5:33 am
Post Re: Backfire
Thanks if it is the timing key where can I get a new one
Mon Jan 23, 2017 6:30 am
Post Re: Backfire
A Briggs and Stratton lawnmower repair shop. Seriously.
A mud motor dealer that sells units with Briggs engines and does repair work should have one as well.
Mon Jan 23, 2017 6:48 am
Post Re: Backfire
Thanks dickhead. We have mud motor dealers on every street corner in Carthage who knew.
Mon Jan 23, 2017 5:01 pm
Post Re: Backfire
WTF?
Mon Jan 23, 2017 5:26 pm
Post Re: Backfire
He wasn't being a dick, fucktard. You don't have to have one nearby to be able to find a phone number for one and call them. You asked where to get a timing key, someone tried to help. Amazon has them too. But I suppose you already knew that and just asked because you wanted to create an Internet test for the people of mmt. You can make one out of aluminum foil if you get creative and you're in such a hurry that ordering one or calling a dealer in another town, city, or state takes too long.
Unappreciative jackass of the week.....
Mon Jan 23, 2017 5:48 pm
Post Re: Backfire
:lol: the "philosopher"
Mon Jan 23, 2017 6:23 pm
Post Re: Backfire
Mon Jan 23, 2017 7:49 pm
Post Re: Backfire
Think she'd be the third or fourth. We had dipstalker and chicklet.
Mon Jan 23, 2017 8:04 pm
Post Re: Backfire
The first 3, as I remember, fit right in.
This is more of a "I'm better than you, and I misread what I was reading and took offense because I have an inferiority complex and thought I was being called stupid" because someone knew something he didn't.
Mon Jan 23, 2017 8:15 pm
Post Re: Backfire
:lol: :lol:
This went south in a hurry! lol
I would say you gotta have thick skin to be around here, but this guy is here and his skins as thin as a piece a paper! :lol:
Tue Jan 24, 2017 4:09 am
Post Re: Backfire
First off my sincere apologies I read that wrong was on my fourth night in row of work. Thanks to everyone of you for the help. It was a push rod that had slipped off the rocker. Put back on checked clearances clean rocker bolt a put lock tite and torqued back down. Can't thank all of y'all enough for the help. Once again please accept my apology for the dick head commit appears the only dick head was me.
Tue Jan 24, 2017 1:15 pm
Post Re: Backfire
Dude, you're the first to ever own up to something like that here. Welcome to the crew, glad you got it fixed.
For the edumication of others, was that on cylinder 1 or 2 (starter side or oil filter side)? Typically if it's the oil filter side, the engine will still crank and run on cylinder 1, but wont on cylinder 2. I only ask because when we help someone troubleshoot, we go off of experiences we or those we know have had, and I'm just curious which cylinder it was.
Tue Jan 24, 2017 1:38 pm
Post Re: Backfire
It was on the oil filter side exhaust valve. FYI don't ever tell my wife I said I was wrong. Also this boat was bought used two weeks ago so probably not adjusted by previous owner.
Tue Jan 24, 2017 9:47 pm
Post Re: Backfire
Sat Jan 27, 2018 1:07 pm
Post Re: Backfire
Sat Jan 27, 2018 3:53 pm
