It is currently Sun Apr 12, 2026 10:31 pm
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 Aluminum weld help
Post Aluminum weld help
Trying to get a hull welded up. Had a couple places that didn't pass the leak test so I ground the weld to fix it. This section had the issue since the very beginning for some reason. It was brushed very good and used acetone and was bone dry. I keep getting these damn holes. The arc acts crazy and smells bad when welding it. I'm at a loss and really not sure wtf to do. Any input?
1850 & 36pd
Sun Feb 12, 2017 3:39 pm
Post Re: Aluminum weld help
Wish I could refer you to this guy, but I dunno who he is.....
Sun Feb 12, 2017 3:59 pm
Yeah I wish he was my neighbor. At the moment I'm ready to hook a chain to it, drag it into the street, and ram this bitch with my hummer.
1850 & 36pd
Sun Feb 12, 2017 4:04 pm
Tried to flood it?
RJ didn't have any tips? Could also maybe reach out to bayoubuster
Sun Feb 12, 2017 4:15 pm
Flood? I talked to Justin and he suggested to wash it with dawn. Just did that and gonna see if that helped. RJ was on a goose hunt this weekend so didn't try him.
1850 & 36pd
Sun Feb 12, 2017 4:19 pm
Yea, use a little too much gas.... I dunno man.
Sun Feb 12, 2017 5:02 pm
I turned it down pretty far and does the same thing
1850 & 36pd
Sun Feb 12, 2017 5:06 pm
You ground it out and had porosity in it again?
Sun Feb 12, 2017 6:04 pm
Yessir. I can't figure it out. I'm gonna play with gun angle and up my gas in a minute.
1850 & 36pd
Sun Feb 12, 2017 6:18 pm
You've either got a very light amount of oil or dirt in the bevel or a light breeze is keeping your gas from shielding the arc
Sun Feb 12, 2017 7:06 pm
Turned the gas up and played with the gun angle. No change. I've wore brushed the hell out of it with a new brush and scrubbed it with acetone on a rag. No breeze because I'm in the garage. May try running a flame over it. I'm kinda at a loss. May just load it up and let another fella put his hands to it. I've welded out the whole boat and along the edges of the floor/bottom of sides has been the only place where this issue has occurred.
1850 & 36pd
Sun Feb 12, 2017 7:26 pm
Man there must be some shit hiding on the bottom edge of that plate. Now way to get it clean now. There is a flowable aluminum "solder" type stuff that you could flow into the contaminated pits
Sun Feb 12, 2017 7:40 pm
Like a brazing rod or somethin different?
Sun Feb 12, 2017 8:00 pm
I'm just gonna clean it up and carry to see if a buddy can do something with it. I'm no welder, I just wanted to build myself a rig so here we are. Also I'm just using a cheap welder and my buddy has one that's the tits so maybe it can get a bead to run in there. I just don't want to end up and ruin my hull by repeating with the same end results. I'm not making any headway.
1850 & 36pd
Sun Feb 12, 2017 8:02 pm
Sun Feb 12, 2017 8:18 pm
Have you tried mag wheel cleaner with acid in it?
Sun Feb 12, 2017 8:24 pm
There's got to be something there. If you can get your hands or have a buddy with a pretty good tig machine that you can adjust the AC Balance to clean, that's gonna be the best bet.
Sun Feb 12, 2017 8:36 pm
Thx for the advice fellas. I'll report back.
1850 & 36pd
Sun Feb 12, 2017 8:58 pm
1850 & 36pd
Sun Feb 12, 2017 10:25 pm
The acid will clean the pores in the metal better than acetone will
Mon Feb 13, 2017 12:02 am
I have only brushed my aluminum with a SS wire brush. I have never wiped with any solvent to make a weld. IMO, you simply need to increase the wire speed. You don't have enough material being fed out for the rate of speed at which you are traveling. And if you travel any slower, you will burn through. Correct? Increase wire speed and let me know. You can also increase wire size to help out depending on what machine you have. I use to use .030, but switched to .035 and had much better results.
Mon Feb 13, 2017 5:20 am
Med, also, what type of wire are you using? My machine was very picky. It would do the job, but when I switched to superglaze, it was like laying down caulk, very smooth. Could also be contaminated wire.
Mon Feb 13, 2017 5:22 am
Banded I'm using .35 in 4043. I'm going to get some new wire and turn it up and see what happens. It's mainly in the last 4ft at the back of the boat on both sides. If it's a no go then I'm going to carry it and see if 5356 will do it. My little machine just won't run it.
1850 & 36pd
Mon Feb 13, 2017 2:14 pm
Right, 5356 takes more input to melt.
Mon Feb 13, 2017 3:32 pm
Are you pushing or dragging?
On certain welds my rig will ball up and leave holes but sometimes will weld perfect when pushing.
Mon Feb 13, 2017 4:37 pm
1850 & 36pd
Mon Feb 13, 2017 4:54 pm
Since it's just getting you in the bottom; I'm betting it's a shielding gas problem. What's your flow rate? Could be too high, creating turbulence in the joint and pulling in atmosphere.
Be careful with what you use to clean aluminum. Using brake cleaner and then welding creates phosgene gas which will kill you. Check out .
Mon Feb 13, 2017 6:12 pm
Usually keep it at 20. I've gone higher and lower with no change. Thx for the article post. Never can know too much. I've only used acetone and dish soap and water for cleaning.
1850 & 36pd
Mon Feb 13, 2017 6:37 pm
How did the inside weld? I have seen that issue before and trash was coming through from the inside weld. Best thing to do is put a tig rig on it and burn out the trash.
Mon Feb 13, 2017 7:09 pm
oil can soak into metal and its hard too clean out acid or burn it out or like txs said from the inside
Mon Feb 13, 2017 7:58 pm
Inside was no issue. Only the outside
1850 & 36pd
Mon Feb 13, 2017 7:59 pm
Drop it off today, we'll either fix it or f it up real good like!!
Sent from my SAMSUNG-SM-G890A using Tapatalk
Sat Feb 18, 2017 11:15 am
That's the attitude! :lol:
Sat Feb 18, 2017 11:56 am
1850 & 36pd
Sun Feb 19, 2017 12:32 am
Try to cut all the way through with a hummer wheel to get anything bad out of there... metal likes to consume stuff especially aluminum it almost magnetizes surrounding junk into the puddle, for example if you burned through there and was welding on wood, you could have pulled the wood up into the puddle and it never wants out. Also the smell could be acetone that worked into the recesses of the porous area and hadn't dried yet, and when it burns that could cause the irradic arc. Long story short I'd cut the problem arc out completely, and re weld... just use caution so the sheet metal doesn't distort! Good luck
"There's nothing a duck hunter hates more than another duck hunter."
Sun Feb 19, 2017 8:29 pm
That's kinda what bayou suggested....cut through and weld it back. I've got some aluminum cutting and grinding wheels on the way. I couldn't find anything especially for al local. The smell existed in the very beginning. First time I tried welding it up I only brushed real good with a ss brush, no chemicals. I started using acetone when I saw there was some sort of issue. The bottom is 3/16 and 1/8 sides so I'm gonna try to get back to square 1 and then remove a little material with the above wheels or a flap. The smell was really odd, kinda like a burnt fart..lol
1850 & 36pd
Sun Feb 19, 2017 9:43 pm
Mon Feb 20, 2017 1:54 pm
Mon Feb 20, 2017 7:58 pm
Tue Feb 21, 2017 7:06 am
Tue Feb 21, 2017 7:14 am
