It is currently Tue Mar 31, 2026 2:43 am
Reply to topic  [ 9 posts ]
 Eliminate return line on ecotrons efi question
Post Eliminate return line on ecotrons efi question
Can the briggs efi fuel module (593890) be used to eliminate the need for a return line on an ecotrons efi kit?
Fri Mar 03, 2017 12:33 pm
Post Re: Eliminate return line on ecotrons efi question
I believe I can answer my own question after reviewing the Briggs EFI repair manual. The Briggs fuel module is designed to provide 35 to 43 psig to the injectors. The Ecotrons kit uses a pressure regulator set to 3 bars that utilizes the return fuel line for pressure relief to provide 43 psig to the injectors. Therefore the briggs fuel module should be able to replace the fuel pump, pressure regulator and the return fuel line on the ecotrons system.
New question, has the briggs fuel module been reliable?
Sun Mar 05, 2017 11:40 am
I have heard of many pump failures, just problems keeping voltage to it
Sun Mar 05, 2017 12:00 pm
Just saw what my speel check did. I meant to say i have NOT heard of many pump failures
Mon Mar 06, 2017 8:54 am
What's a speel check? :lol:
Mon Mar 06, 2017 8:57 am
Lol, im just fired!
Mon Mar 06, 2017 9:34 am
Thanks for the info and smile. Now for the Rhetorical question; Is it worth $235 (cost of fuel module) to clean up/ simplify the fuel delivery system?
Mon Mar 06, 2017 8:01 pm
If it aint broke... :roll:
Mon Mar 06, 2017 11:10 pm
Break it?
Mon Mar 06, 2017 11:24 pm
