It is currently Sat Jun 21, 2025 11:59 pm
Reply to topic  [ 10 posts ]
 Mud buddy trim quit
Post Mud buddy trim quit
Need help suggestions please
Sat Mar 25, 2017 4:34 am
Post Re: Mud buddy trim quit
Here I will help you.
I suggest you describe what is going on with your trim unit so that someone can know how to help you.
Sat Mar 25, 2017 11:34 am
If it quit working I'd probably just fix it.
Sat Mar 25, 2017 11:53 am
I'd start with the rocker trim switch in the football to make sure wiring was ok. Next I would check up and down relays to trim unit. Next the circuit breaker to trim motor. Then I would check the trim motor by reversing wires from it to a battery to see if it goes up and down. A multimeter comes in handy when checking switches and wiring. If all else fails take it to a dealer.
Sat Mar 25, 2017 5:15 pm
Sun Mar 26, 2017 11:26 am
Did you check the inline bus fuse?
Sun Mar 26, 2017 1:04 pm
[quote="BERNIE255"]Did you check the inline bus fuse?
Don't know that there is one, if so I'm not sure where it's at
Sun Mar 26, 2017 3:48 pm
What trim do you have
Tue Mar 28, 2017 4:59 pm
Mercury
Wed Mar 29, 2017 7:15 pm
It was a circuit breaker
The original was a 20 amp was told to replace with a 40 amp
Should not be a problem any more but I'll keep a jumper wire just in case
Thu Mar 30, 2017 6:57 pm
Users browsing this forum: No registered users and 391 guests
