It is currently Fri Apr 03, 2026 3:08 am
Reply to topic  [ 19 posts ]
 gator tail clutch leak
Post gator tail clutch leak
my clutch is leaking fluid from the seal located behind the clutch on the back side of the reservoir. i think i will change the fluid to a heavy weight oil, clean it up, and run it. if this doesn't work, any ideas how hard that is to take apart?
grr 37 on 1854
Wed Apr 05, 2017 6:15 pm
Post Re: gator tail clutch leak
Not very difficult if you have turned a wrench before.
If you have to run to Home Depot to buy tools... better to call a professional.
I installed a new seal about 12 months ago and now use a heavier oil.
Thu Apr 06, 2017 5:32 am
My old motor used to do it. They said nothing to worry about just put some heavier oil in. They said they have ran those things dry for 200 hours with no issues, just looks bad when oil is leaking from your $9,000 motor :lol: used to drive me nuts
Thu Apr 06, 2017 5:46 am
Go to a heavy gear oil and set the bottom screw at 9 o'clock at the highest. It doesn't take much oil at all
Thu Apr 06, 2017 4:19 pm
9 o clock? That makes it horizontal. Pretty sure it's 10 or 2 for the top one.
Thu Apr 06, 2017 4:23 pm
The clutch has fluid in it? :?
Thu Apr 06, 2017 5:02 pm
thanks for the input. i called gator tail and they said to make sure i didn't overfill it first, so i cleaned it up and refilled with exactly 1 ounce. ill try it out this weekend. they did give some instruction on how to change the seal if need be. ill check back in after my weekend trek.
grr 37 on 1854
Thu Apr 06, 2017 5:58 pm
The planetary. You know what he meant. Lmao
Thu Apr 06, 2017 6:22 pm
Fri Apr 07, 2017 5:49 am
Fri Apr 07, 2017 7:17 am
Fri Apr 07, 2017 7:19 am
I just assumed he meant the planetary when he mentioned oil leak.
Maxxis... post up a video of servicing clutch oil :mrgreen:
Fri Apr 07, 2017 7:22 am
Fri Apr 07, 2017 7:58 am
Fri Apr 07, 2017 10:34 am
What weight oil yall using in there? I started out with 10w30, that leaked. then I went to gear oil, that is leaking as well...
2015 1854 Prodigy Evolve Side Console 37 GTR
Mon Apr 24, 2017 6:27 am
I have always used 30w, but mine has not started to leak yet(300 hrs.). When it does?
Mon Apr 24, 2017 8:07 am
I've got 110hrs on mine, been leaking for about 40hrs. Doesn't effect performance ( I don't think), but I don't know if it's wearing things our prematurely. Also annoying having oil all over the place.
Mon Apr 24, 2017 8:25 am
Have them send you a new seal. Mine leaked after 17 hours, called and had a new seal shipped covered under warranty and removed the seal. It took about 45 min from start to finish to replace so it's a really easy fix.
Tue Apr 25, 2017 7:43 am
Just called and got a seal shipped. Whats involved in replacing it, Ive never taken the planetary or transmission as they call it apart.
Tue Apr 25, 2017 9:46 am
