It is currently Tue Apr 07, 2026 4:50 pm
Reply to topic  [ 18 posts ]
 mikuni for Kohler 27
Post mikuni for Kohler 27
I did a search on this, came up with an old thread from 2010. Member named drake1 said they put 33mm mikunis on kohlers, worked great. He no longer is on the forum, last post was 2015.
I am looking for someone who has info on adaptors to manifold, and any other info they can lend. I am no stranger to v twins, spent decades working and riding harleys, familiar with mikunis for them and jetting. Anybody got a direction to point me?
Thanks in advance. Dennis
Wed Apr 05, 2017 5:48 pm
Post Re: mikuni for Kohler 27
They made an adapter that fit the two barrel kohler intake. Nobody makes the adapters anymore.
Wed Apr 05, 2017 7:04 pm
This is the intake, I havnt looked for an adapter
Wed Apr 05, 2017 8:07 pm
35 carb fits though
Wed Apr 05, 2017 8:12 pm
I thought it did but didnt remember for sure. If thats the case, the intake adapter for the briggs would fit. Maybe could use some putty or something to smooth out the difference in carb size so theres no turbulence.
Wed Apr 05, 2017 9:22 pm
Its not a dual throat manifold or carb. Single barrell. Bore looks like 22mm, outside bore is 38mm.
I'm thinking a 33 or 34 mm would be the right step. Another thought, without stock carb in place, no governor, so no max RPM. Does anyone know if the CDI has built in rev limiter?carb.JPG
Thu Apr 06, 2017 10:01 am
Thu Apr 06, 2017 10:16 am
Yes but just saw its on a PD. My intake is for a horizontal
Thu Apr 06, 2017 10:51 am
Thu Apr 06, 2017 10:53 am
Thu Apr 06, 2017 10:55 am
Thu Apr 06, 2017 1:04 pm
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Thu Apr 06, 2017 1:32 pm
Thu Apr 06, 2017 4:57 pm
Damn, CB, you so smart.
Glad you're on our side. :lol:
Fri Apr 07, 2017 3:04 pm
You should talk your buddy into dumping the kohler and slapping a big block on that frame. His money will go much further that way, and the end result will be much better. I've been down this road before.
Fri Apr 07, 2017 6:38 pm
Fri Apr 07, 2017 8:39 pm
Sat Apr 08, 2017 5:06 am
Sat Apr 08, 2017 10:09 am
