It is currently Wed Apr 08, 2026 10:01 am
Reply to topic  [ 4 posts ]
 Need some suggestions
Post Need some suggestions
Im a new surface drive owner. I have a 16 44 alumacraft with a 37efi GTR. My problem is the amount of tourque the motor has at full throttle. It takes almost everything I have to keep it from going to the right. Any help would be appreciated. Thanks
Sat Apr 08, 2017 5:09 pm
Post Re: Need some suggestions
#1 play with the trim and hole settings. If you are trimmed out of water too much, the torque goes thru the roof. On my boat there's a sweet spot.
#2 You can bend the back of the skeg (on my 2014, there's a distinct tab) more
#3 you can mount the motor slightly off-center (like 1" or less) to the starboard (if that's the way it's pulling)
Mon Apr 10, 2017 6:21 pm
Dont bend the skeg if its a cast lower unit...it wont bend, it'll just break. Move weight around or move off center
Fri Apr 14, 2017 2:26 pm
Or jb weld a wedge to the skeg. Or bolt a tab to the skeg to bend
Fri Apr 14, 2017 3:36 pm
