It is currently Tue Mar 31, 2026 10:18 am
Reply to topic  [ 10 posts ]
 Cam supplier
Post Cam supplier
i speced out 3 cams ive got here from the same supplier. 2 are 2 teeh off from where they should be and 1 is 1 tooth off from thier timing marks and none are the specs i asked for. Seems no matter how many times i ask for spec cards to come with the cams i dont get those either so i am done with them. Looking to have dyno cams build them now. Are yall getting what u ask for from them with spec cards?
Mon May 01, 2017 8:06 am
Post Re: Cam supplier
Care to make a PSA and disclose the suppliers name?
"There's nothing a duck hunter hates more than another duck hunter."
Mon May 01, 2017 9:18 am
No sir im not going there, just looking to move forward
Mon May 01, 2017 9:29 am
well the cam gear has 70 teeth. and each tooth 5.14 Degrees. The cam makes 1/2 revolution per crank Revoluion so to make a full cycle we have 720 degrees of crankshaft operation in a camshaft event.... So in essence one tooth off is 10.28 degrees wrong.. That's a big deal man. You have slack and cam walk that can alter your specs a little....but that's bad.
Mon May 01, 2017 10:04 am
Yea the dots being off isnt the end of the world if u check it. But even setting them where they would work is still not what i ordered. Sooo is dyno cams getting a thumbs up?
Mon May 01, 2017 10:26 am
Mon May 01, 2017 10:46 am
No other dots. That would be too easy :D
Mon May 01, 2017 11:23 am
Mon May 01, 2017 12:22 pm
Just want to give a thumbs up to Dyno. They built exactly what i asked for down to the exact degree. Happy customer :D
Mon May 15, 2017 9:00 pm
Tue May 16, 2017 5:37 am
