It is currently Tue Mar 31, 2026 8:48 am
[ 9 posts ] |
spooky
 wiring kill switch
Is there any " how toos" on how to wire in a kill switch on a 13hp? Thanks
| Tue Aug 15, 2017 7:03 am |
MaXXis85
 Re: wiring kill switch
tap into the engine "kill wire"
| Tue Aug 15, 2017 8:06 am |
spooky
Thanks for the reply. where might that be located? Also, my kill switch has 3 prongs on it if I remember right. Im guessin that that once I locate the "engine kill wire" its one in and one out but where does the 3rd prong go.
| Tue Aug 15, 2017 10:40 am |
Bigbend
Joined: Sat Dec 11, 2010 6:25 am Posts: 493 Location: SWGA
Most of them have 4 prongs, but you only use 2 of them. Wire it up, try to crank it. If it doesn't crank move the connector to a different prong. Once it cranks, verify the switch will kill the engine. Quick lazy way I normally wire them up.
The kill wire is located on the side of the engine. The little switch that turns it off. Is it a Honda?
| Tue Aug 15, 2017 3:07 pm |
spooky
| Tue Aug 15, 2017 4:09 pm |
Bigbend
Sounds like a duromax, does it have the little dial kill switch on the side? If so, tap into that.
| Tue Aug 15, 2017 5:15 pm |
spooky
no, its a electric start / key
| Tue Aug 15, 2017 7:45 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
the Black wire with the red stripe is your kill wire going to key ignition. tap it and run to your "kill switch" or find it coming out from under your engine cover.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Wed Aug 16, 2017 7:52 am |
spooky
10/4 Thanks! Ill look for it today after work. I could just go without it (like some do) but I understand the importance of it.
| Wed Aug 16, 2017 1:51 pm |
[ 9 posts ] |
