It is currently Sun Mar 29, 2026 9:28 am
[ 6 posts ] |
DenaliHD
 37 EFI Dipstick Tube
Anyone ever manage to break one? Fix for it? Was thinking I could use an easy-out to extract the remainder of the tube from the block and just order a new one and slide it in with a new stick? Thoughts? Its got probably 1/2" sticking out of the port..
_________________ 1848 Uncle J L3 40XD EFI GTR
| Mon Aug 21, 2017 7:24 am |
Will C
 Re: 37 EFI Dipstick Tube
Here is pic, you should be able to grab the boss or chunk of meat at the base with visegrips and twist it back and forth with working your way up
| Mon Aug 21, 2017 7:40 am |
MaXXis85
You cannot buy one. Remove one from a cracked cover if you can locate one.
| Mon Aug 21, 2017 7:48 am |
DenaliHD
So if you can't buy it, what's the fix in the case it breaks?
| Mon Aug 21, 2017 7:54 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
clean up the end of the old one and cut off dip stick to a correct length.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Mon Aug 21, 2017 8:07 am |
Russ
I may have one. I'll look when I get home
| Mon Aug 21, 2017 8:45 am |
[ 6 posts ] |
