It is currently Sun Mar 29, 2026 2:23 pm
Reply to topic  [ 11 posts ]
 First Oil Change and Valve Lash
Post First Oil Change and Valve Lash
I just hit ten hours on my GTR XD 37 EFI with Level Three Delta Performance upgrade.
I used the Briggs filter and Rotella T6- 5W-40 (Recommended by Delta), and lubed the lower with marine grease.
Now for the valves. I have yet to do valves, but I does not look all that difficult. Does anyone recommend a good YouTube video on how this is done before I tackle it?
The sheet I got from Delta reads "When performing these Valve Lash Adjustments, we recommend that the lash be set at .005" stock rockers. Roller Rockers are recommended at .006 on intake Rockers, and .008 on exhaust Rockers"
Not exactly sure what that means.
Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
Thu Sep 07, 2017 12:25 pm
https://r.tapatalk.com/shareLink?share_ ... are_type=t
There is a video on that thread that will explain setting valve lash.
Thu Sep 07, 2017 1:26 pm
Post Re: First Oil Change and Valve Lash
Exhaust opening , intake closing method.
When the exhaust valve JUST opens, set intake valve lash.
When the intake ALMOST closes, set the exhaust lash.
Thu Sep 07, 2017 2:16 pm
I will add when locking the locknut support the rocker and dont put pressure sideways on the pedistal
Thu Sep 07, 2017 2:41 pm
Fri Sep 08, 2017 5:15 am
I must be doing this wrong! I have been setting my valves with the on piston top of compression stroke, thus ensuring both valves fully closed. This doesn't work correctly?
Fri Sep 08, 2017 8:00 am
Yes you are doin it right, just dont break a pencil off in there checking for tdc :D theres more than 1 way to skin that cat
Fri Sep 08, 2017 8:03 am
Fri Sep 08, 2017 8:36 am
EOIC method is more refined to ensure you are on the cam's base circle...
Fri Sep 08, 2017 10:08 am
Fri Sep 08, 2017 11:24 am
Fri Sep 08, 2017 12:10 pm
