It is currently Tue Jun 04, 2024 12:59 am
Reply to topic  [ 18 posts ]
 Gear teeth on my 2012 gtr
Post Gear teeth on my 2012 gtr
I have a 2012 35 gtr With hydraulic reverse wanting to know how many teeth or on the top pulley and how many teeth is on lower pulley on a stock gtr also what is the prop size and Pitch it is in a two blade and a three blade if any one know
Mon Jan 08, 2018 5:41 pm
Post Re: Gear teeth on my 2012 gtr
Take the transmission cover off. It'll have a 48 stamped on either the right or left side if it is 48
Mon Jan 08, 2018 6:05 pm
Mon Jan 08, 2018 8:24 pm
The bottom is 48. The top is what ever you count to. I don't think the top has ever changed. I think the ones changed around 2012 went from 42 to 48 but I may be backwards.
Mon Jan 08, 2018 8:27 pm
The bottom used to be 45, changed to 48 around that time. The top is 36, I think. Marcus will be along shortly to correct me if it's 38.
#TheGhostBoat
Mon Jan 08, 2018 8:36 pm
Mon Jan 08, 2018 8:37 pm
12x10
#TheGhostBoat
Mon Jan 08, 2018 8:39 pm
Mon Jan 08, 2018 8:40 pm
If Russ says it is, then it is. Thanks for the correction on 45 and not 42. Drinking beers and watching Alabama hopefully lose doesn't make for a strong memory of obscure facts.
Mon Jan 08, 2018 8:43 pm
If u always have to push away with the tiller handle from u which way should I bend the tabs thanks
Mon Jan 08, 2018 8:48 pm
Away from you. Check your weight distribution first and also prop plays into effect. Since you have a worn prop, may want to wait till you have a new one and see how that plays in.
Mon Jan 08, 2018 8:51 pm
Trim level affects the felt torque a lot, and a fresh prop will change where it's trimmed for best thrust. Unless you're gonna use that prop a while, just wait on the bending stuff.
#TheGhostBoat
Mon Jan 08, 2018 8:55 pm
Thanks baggy’s got my prop now to get work
Mon Jan 08, 2018 9:09 pm
Top gear is 38 Current bottom is 48. Used to be 45 lower, but was changed around 2011-2012 ish. The CDI motors additional charging system put more load on these units aswell as larger boats, 3 blade propellers were coming out; so they needed a lower gear ratio.
38/45 = 1.18:1
38/48 = 1.26:1
Tue Jan 09, 2018 6:18 am
I have a 2011 GTR CDI
its a 38/45 and came stock with a power tech 12x10
Tue Jan 09, 2018 10:39 am
Tue Jan 09, 2018 1:51 pm
Thu Jan 11, 2018 7:41 pm
Port side top of belt box.
Fri Jan 12, 2018 7:36 am
Users browsing this forum: No registered users and 79 guests
