It is currently Wed Apr 01, 2026 6:28 am
Reply to topic  [ 23 posts ]
 Let's talk Pro-Drive Upgrades
Post Let's talk Pro-Drive Upgrades
Hey guys...
I'm pretty new on here...surf around a lot looking and reading.
I got my first mud boat back in fall of 2013. I'm running an 1856 Phowler Extreme MV, with a stock PD 36 Gen 3 on it. 3 blade prop.
I've posted a little this year talking about speeds and such and trying to figure out what I can do to nurse a little more umph out of my motor and ride. It's been seeming really slow when it's loaded down with a bunch of stuff.
The end of this season I was running in the upper teens, 15 - 18 loaded down, which I wasn't so pleased with.
When I say loaded down here's one example...
Myself (260), dog (72), gun box (guns, coffee thermos', throwable cushions, 2 guns, anchor, all the miscellaneous junk we seem to need EVERY time we go duck hunting), 12g gas (under the extended deck in front of the boat, running 93 no ethanol fuel), Box with an extra set of clothes and prop in it, decoys...decoys...decoys...2 dozen foam filled divers, 5 dozen g&h weighted keel divers, a dozen golden eyes, 2 layout blinds, a dog blind, and blind bags. Does anybody ever take enough stuff when they go hunt!? :shock:
So, with that load, I'm running DEEEEP water lakes here in Tennessee, so I'm getting those 15 - 18 mph speeds, feeling like I'm pushing water as hard as I can, not wanting to jump on pad and just sluggish...
So with that being said, I've been looking at the upgrades I can do on this motor...
Here's my wants...
I want something that moves on decent and gets me in and out easily.
I want to be able to get up on plane so I'm not getting pelted with water spray the whole time
I DON'T want to cam it...I feel like that just kills the longevity of the motor. I don't run this motor hard...I usually just turn around 4000 rpm. Which may be a big part of my problem. I've been told 4200 or so seems to be the sweet spot for these motors so I probably haven't been trimming it up high enough to get that rpm, because it will run on up to those rpms if I ask it to.
So I'll stick with the carb motor for right now...I have a 6 year old, just built a house, building a horse barn, 6 year old and wife showing horses so you get the point...
So, for upgrading a stock PD 36 Carb Gen 3 what do you do...
Fri Feb 09, 2018 11:06 am
Post Re: Let's talk Pro-Drive Upgrades
That's a pretty good load for any stock motor. Might help with a prop change, maybe something with less pitch and more diameter. Not being able to change gearing in drive like you can on a belt driven motor, kind of limits what you can do.
Fri Feb 09, 2018 11:24 am
I'm not a PD owner but heads would be my #1. Also can you change to gen 4? I thought the gen 3 was the notoriously slow lower.
Fri Feb 09, 2018 12:26 pm
Fri Feb 09, 2018 12:40 pm
Ive been messing with a gen 3. Stage 2. Its respectable but even with a "special" worked gen 3 prop its spins a lot coming out of the hole and top end is decent but not where any other frame would be with the same motor. For you a carb/heads motor with a worked prop would be a major improvement. If anyone else has some magic gen 3 info I'm listening
Fri Feb 09, 2018 1:07 pm
Swapping to a Gen4 lower, what cost would be involved in that?
I hear and see a lot of things but what is really the "stages" of upgrades?
Fri Feb 09, 2018 1:09 pm
Use the search feature for the stages but in general they are a combination of headwork (~$700), cam ($400 part, not including labor), carb (~$800 new), and performance exhaust (~$75 to gut stock up to probably $700 for high end performance). Most everyone agrees that headwork is the biggest bang for the buck upfront. After those mods you can do other things but those are the major ones.
Fri Feb 09, 2018 1:21 pm
Fri Feb 09, 2018 1:23 pm
My .02
Have someone work your heads, buy a Mikuni kit, and get a decent flowing exhaust. Run a 2 blade prop, or get a 3 blade worked from Baggy with some more cup so it doesn't slip like crazy coming out the hole. Gen4 swap is only going to benefit you with a little bit more top end speed...What it seems like you are missing is the power to get that load on step, not just push it 2 mph faster.
Fri Feb 09, 2018 3:07 pm
Fri Feb 09, 2018 7:38 pm
Just get Will C, Maxxis, or Boat Dr to do your heads. They've done it a lot and have their recipe down pat.
Fri Feb 09, 2018 8:25 pm
Heads, carb, exhaust gave me an extra 5 mph(24-25top speed to 29-30mph) allowed me to hit the rev limiter on a CDI w/4350 coils. Also it would turn a hammer pretty damn good. With that being said, Heads and exhaust to start if you want to spend less, or go for it and do all three.
I am a little impatient so, I bought the "kit", carbs, heads, and BPS Q from BPS and did it myself in one long afternoon. The only issue was the Mikuni had a 160 jet(way too lean) I changed it to a 172.5(still not sure if that is rich enough).
Sat Feb 10, 2018 9:12 am
Sun Feb 11, 2018 8:50 am
I had a gen 3 and looked at doing the lower unit swap they quoted me about 2000 of i remember right. Ended up selling it and buy one that was alrdy swapped and has head mukuni and a marsh mellow. Runs right at 30 with 12 gallons of gas 6 life jackets winch 2 batteries up front one in the back and misc stuff in front deck storage and me at about 230lbs with a baggy worked prop in choppy deep water. Havnt had it in the shallows yet. Ran 24-25 with same load plus 500lbs of ppl before the prop in the shallows
Sun Feb 11, 2018 4:29 pm
Depends on your budget, but I think swapping to a Gen 4 ,ay be more than you want to bite off based on your comments. If you had to do it in phases, I would do Heads First, Mikunie 2nd, Cam 3rd (that’s me I know you don’t want a new one) and exhaust 4th. I would try to keep your compression in the 170-190 range for performance and longevity. I
Sun Feb 11, 2018 5:11 pm
if you are running deep water and want more speed, it might be alot cheaper to buy a used outboard and swap it out with your mudmotor. that way u have a reliable mud motor when u need it, and the convienance/speed of a outboard when that's what u need.
A $1500 40-60 hp outboard might be the way to go and/or be another option for you.
good luck either way.
Sun Feb 11, 2018 8:50 pm
OR..... the money you would spend on a gen4 lower, and all the other shit, Buy a kawasaki and be done with it. Cheaper to mod, and if you deck the heads (stock valves) port and clean up, stock cam with exhaust, you will be able to tote elephants at 27+ mph with the stock cam.
Mon Feb 12, 2018 4:55 am
Mon Feb 12, 2018 9:08 am
:lol:
Mon Feb 12, 2018 12:31 pm
Good night I'd love a Kawasaki sitting on the back of mine. It would be unreal!
Mon Feb 12, 2018 12:45 pm
Mon Feb 12, 2018 2:04 pm
a 60 merc would make that kawi shit it's pants. lol
Mon Feb 12, 2018 8:46 pm
Tue Feb 13, 2018 5:09 am
