It is currently Fri Mar 27, 2026 3:21 am
[ 8 posts ] |
Pd 37 higher idle and sputtering
woodie_slayer
My pd 37 was acting weird when my idle earlier was around 850-900rpms then after cranking up 2hrs later it randomly increased to 1060-1080rpms and wouldn't decrease.Then after that,i put it in gear and it sputtered the whole time with the throttle wide open .So i turned it off for 5 mins and it went away.Has anyone had this happen or have a clue whats going on?
| Mon Mar 05, 2018 12:19 am |
Will C
 Re: Pd 37 higher idle and sputtering
Check engine light blinking at you?
| Mon Mar 05, 2018 9:10 am |
woodie_slayer
Its not the updated efi
| Mon Mar 05, 2018 9:17 am |
Will C
It would be nice if a shop in your area can check the ecu for codes. Aside from that clean and tighten ground and power wires at engine and at battery
| Mon Mar 05, 2018 9:56 am |
woodie_slayer
Ok will do.does it sound like a surge somewhere to you Will? This thing had me dumbfounded yesterday,thankfully the fish were biting 400yds off haha.
| Mon Mar 05, 2018 10:07 am |
MaXXis85
Also I have seen mis adjusted TPS sensors, but it sounds like a simple connection issue.
| Mon Mar 05, 2018 11:04 am |
woodie_slayer
Alright fellas I found out what it was the hard way.it was the ground to the battery and it burned the crap out of me.thank y'all for helping out,I appreciate it.
| Wed Mar 07, 2018 7:01 pm |
Will C
Easy fix,,, good deal
| Thu Mar 08, 2018 1:31 am |
[ 8 posts ] |
