It is currently Thu Aug 20, 2026 12:42 pm
Reply to topic  [ 9 posts ]
 Frog box
Post Frog box
I️m looking into building a new frog box just seeing what everyone else uses
Wed May 02, 2018 4:47 pm
Post Re: Frog box
Only guy I know that goes frogging just pulls rubber roof material over a bucket and holds it tight with a hose clamp. Then cuts a slit for the frogs.
I’m sure you down south are more sophisticated.
Wed May 02, 2018 5:42 pm
Post Re: Frog box
La Boat Worx can build you a nice one
40HP Gatortail
Thu May 03, 2018 7:33 pm
Post Re: Frog box
what exactly is a "frog box"?
Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
Thu May 03, 2018 8:48 pm
Post Re: Frog box
Use a live basket with a spring loaded lid. Get em at academy for 25 bucks and can fit about 80 frogs in our. Easy to drop them in and impossible for them to hop out.
Sun May 06, 2018 7:47 pm
Post Re: Frog box
An old cooler works just fine.
Mon May 07, 2018 9:07 am
Post Re: Frog box
i always killed mine before I put them in a Bucket, but them suckers do have a habit of reviving.
Wed May 16, 2018 7:43 am
Post Re: Frog box
[quote="stu"]An old cooler works just fine.
I use an old ice chest and cut a small rectangle in the top with a jigsaw.
From the inside of the top, I closed that hole with a piece of plywood and a door spring/hinge bolted to the plywood and the cooler.
When you push the frog in, the little door closes behind your hand. I will post pics later.
Fri Aug 24, 2018 1:44 pm
Post Re: Frog box
I get a short piece of 3 or 4'' pvc and tape a decoy sack to it, then hang it on the side of the boat. throw frogs in till u get worried about them jumping out, then throw the sack in a icechest and tape on another one.
I got tired of scratching my hands up on my wire frog cages.
Sat Aug 25, 2018 1:30 pm
