Plandr5
 What are the benefits of lower hp if price isn’t an issue an
I’m looking at getting a gatortail.
Outside of price what would be the benefit of a 35 hp over the 40? I believe the 35,37,and 40 all weigh the same and I understand what I can afford but would there be a time when you can argue it’s simply too much motor in terms of hp?
Dropping it on a 16x48 gatortail with a timber deck so 17x48 overall.
| Sun Jun 10, 2018 9:56 pm |
Will C
 Re: What are the benefits of lower hp if price isn’t an issu
As far as hp don't think the 40 would ever feel like too much hp. I would say the the only advantage to a 35 is that it's still a carb motor . For the man that wants to wrench on it himself the carb motor is the most straight forward.
| Sun Jun 10, 2018 10:11 pm |
kib876
Joined: Tue Dec 15, 2009 8:16 am Posts: 612 Location: Orange, Texas
If I’m not mistaken, a gator tail 16x48 will be a 16x48 even with hunt duck. They don’t add to the length like gator-Trax
| Mon Jun 11, 2018 2:39 am |
Koondog62
| Mon Jun 11, 2018 3:16 am |
Swampin
[beliewould there be a time when you can argue it’s simply too much motor in terms of hp?
Dropping it on a 16xf48
Sent from my iPhone using Tapatalk[/quote] IMO NO! You won’t have too much HP
| Mon Jun 11, 2018 6:21 am |
DENNYEDWARDS
Joined: Sun Aug 09, 2009 12:50 pm Posts: 574 Location: Muscatine, Iowa
Terms of boat handling HP you should be ok with the 40 hp on a 1648. I run a moded MB 45 on a 1648 hull with no problems.
| Mon Jun 11, 2018 10:22 am |
Plandr5
I thought the same. I saw the original invoice and they called it 16 though it’s 17 tail to tip and wlf registration lists it as 17
| Mon Jun 11, 2018 5:26 pm |
Plandr5
[quote="Swampin"][beliewould there be a time when you can argue it’s simply too much motor in terms of hp?
| Mon Jun 11, 2018 5:30 pm |
banded-mallard
The main benefit of lower HP motors is "IF" you hunt WMA HP restricted areas. I know CLF is strick on modded motors. Not even aftermarket exhaust.
| Thu Jun 14, 2018 4:32 am |
kirk
Joined: Thu Apr 18, 2013 5:52 pm Posts: 870 Location: SW LA
| Thu Jun 14, 2018 5:44 am |
jc
No such thing as too much hp. Just decide if you want a carb or efi. You can always modify either.
| Thu Jun 14, 2018 5:29 pm |
