It is currently Fri Sep 19, 2025 1:52 pm
Reply to topic  [ 10 posts ]
 Hydro turf application?
Post Hydro turf application?
I bought a roll of hydro turf off ebay for cheap. It doesnt have any 3M backing. What are the best ways to stick it to your boat that yall have seen hold up to time and abuse. Thanks in advance
Tue Aug 14, 2018 6:26 pm
Post Re: Hydro turf application?
3m spray adhesive
#TheGhostBoat
Tue Aug 14, 2018 6:50 pm
^ what he said
Tue Aug 14, 2018 7:38 pm
Wed Aug 15, 2018 9:55 pm
I used 3m hi-strength 90
1648MV SeaArk 37 EFI Backwater SWOMP Lite
Thu Aug 16, 2018 6:04 am
Roll DAP contact cement on the back off the hydroturf and on the surface it's going on and let it set until it's tacky-almost dry. Then apply hydroturf and press it into place. Done....will not move or come loose
SWOMP Lite 23 Glider with 22hp Predator on 1542 Landau mod v
Thu Aug 16, 2018 6:43 am
1854 Brother Breaux and Boss 40XP and 90hp outboard.
Thu Aug 16, 2018 9:51 am
Did mine with contact cement. Holds it great but reacts with the turf and allows it to expand a bit.
Sat Aug 18, 2018 12:38 pm
Sat Aug 18, 2018 1:01 pm
Loctite makes a spray adhesive that's good too. You're not trying to hold a car up in the air that's glued to the bottom of an airplane. The 3m stuff is fine, and is quite similar in bond strength to the stuff that comes preapplied. There are a half a dozen other options, too, that would work as well. Just pick one, clean the boat surface properly (which will matter more than whether you use contact cement, 3m spray, or elephant jizz, then apply and roll out.
#TheGhostBoat
Sat Aug 18, 2018 1:32 pm
