It is currently Fri Mar 27, 2026 6:31 am
Reply to topic  [ 19 posts ]
 Red Hot Exhaust
Post Red Hot Exhaust
It was very dark on my way back in tonight. On my way in a noticed my exhaust was glowing red toward the middle on the right. It is probably normal, but I thought I would ask here. I probably just noticed for the first time because I recently took of my heat deflector to accommodate the mikuni and filter.
Sun Oct 28, 2018 5:33 pm
Post Re: Red Hot Exhaust
yep, it's normal, especially on a long run.
Sun Oct 28, 2018 5:35 pm
Thanks :D
Sun Oct 28, 2018 5:55 pm
My voodoo always is red at night or in the cold bro, it's Normal
Sun Oct 28, 2018 6:10 pm
May be, maybe not. My exhaust doesn't glow, never has. My dad's did with the old exhaust. New one doesn't. You'd probably benefit from checking the afr, you might be lean on that cylinder.
#TheGhostBoat
Mon Oct 29, 2018 9:14 pm
[quote="Russ"]May be, maybe not. My exhaust doesn't glow, never has. My dad's did with the old exhaust. New one doesn't. You'd probably benefit from checking the afr, you might be lean on that cylinder.
new motor with warranty...... roll dat biatch!!!!! lol :)
Mon Oct 29, 2018 9:20 pm
Weird thing I learned the other night, it glows red hot if the baffle is in it, if the baffle is out, it doesn't :roll:
Mon Oct 29, 2018 11:27 pm
Tue Oct 30, 2018 5:19 am
Tue Oct 30, 2018 5:43 am
It's fine. Don't stress it. And the afr I'm talking about is under full throttle, and you'd need a meter or gauge, an O2 sensor or 2, and a little patience. Don't worry with it.
#TheGhostBoat
Tue Oct 30, 2018 6:46 am
Wchauvin, since you have all the bolt ons I would love to know where your afr is running out of curiosity.. or how your plugs look after a run.
Tue Oct 30, 2018 7:37 am
Alll I have is the voodoo and the k and n air filter bro. I pull my plugs when I do my maintenance and so far they look good pretty good. Any particular things I should be looking for?
Tue Oct 30, 2018 12:26 pm
I saw when u mentioned u run baffle out sometimes. I think u have the fastest stocker out there. If your bored one day send me a pic of your plugs. I know she running good no doubt. I'm just wondering where the afr is on a stock 40 with the baffle out on a voodoo. I do efi tune work and just curious
Tue Oct 30, 2018 1:29 pm
Sure thing bud, I'll hit you up
Tue Oct 30, 2018 6:25 pm
Pm me your number and I'll send you some pics over the next two days bro
Tue Oct 30, 2018 6:27 pm
I'll send it
#TheGhostBoat
Tue Oct 30, 2018 7:34 pm
Wait till them heads and cam get into that 40 LOL
Wed Oct 31, 2018 12:48 pm
Going to run over 40 if you get your hands on it bro lol
Wed Oct 31, 2018 8:11 pm
Thu Nov 01, 2018 6:02 am
