It is currently Mon Feb 23, 2026 10:31 pm
[ 6 posts ] |
Phantasm
 Mud Buddy Black Death 45
New carburetor rebuild , new Fuel Pump Pump ball until it gets hard while in launch and trimmed to prevent rev limiter motor runs full throttle for what is seems like the carburetor bowl runs out of fuel then dies restart pump ball and repeat process ,, Any ideas
THIS ISSUE WAS THE SAME BEFORE THE CARB REBUILD AND FUEL PUMP REPLACEMENT. bowl was adjusted becuase after loacal shop rebuild fuel constintly flow from carb overflow tube
| Sun Dec 02, 2018 5:12 pm |
Will C
 Re: Mud Buddy Black Death 45
Sure sounds like starving for fuel. Fuel line issue, air from tank fitting, weaker than normal pulse to pump, tank in front with a long line, line too big "fuel is heavier in big line" pump can't pull it up,, just some ideas here.
| Mon Dec 03, 2018 1:29 am |
Phantasm
After I posted I told myself to start with the simple things , so today I will change commercial style filter and new bulb, my fuel tank set has been the same for over 10 years located right under engine, one condittion i amnot familiar with is how the fule pump is dirven and how to troubleshoot.
| Mon Dec 03, 2018 6:13 am |
Wchauvin
Remember to loosen your gas cap too bro if you don't have a vent on your tank. That has helped me with similar issues in the past
| Mon Dec 03, 2018 6:43 am |
Phantasm
blue ethanol fuel safe hose was the culpert , hose had a thin plastic lining which would collapse under suction of fuel pump,,,,
| Wed Dec 05, 2018 5:48 pm |
Wchauvin
Good info bro
| Wed Dec 05, 2018 7:36 pm |
[ 6 posts ] |
