It is currently Thu Apr 02, 2026 8:43 am
Reply to topic  [ 3 posts ]
 DOT 3 or DOT 5 brake fluid
Post DOT 3 or DOT 5 brake fluid
Had to do some maintenance on the Gator Tail reverse and now I have to put brake fluid back in, but I don't know which to use. I am not sure what was in it before, DOT 3 or 5. The manual I found online says DOT 5, but I have also read that with the older calipers, you should use DOT 3. The motor is a 2011. Anyone have any idea/input? Thanks.
1748 Mike Kliebert with a 37 Prodrive
Sun Feb 17, 2019 1:15 pm
Post Re: DOT 3 or DOT 5 brake fluid
I think it would be dot 3 but you need to know for sure because dot 5 is not compatible with any of the other brake fluids. I would call gator tail or maybe maxxis or someone who knows will let you know for sure.
Sun Feb 17, 2019 4:40 pm
Sun Feb 17, 2019 7:57 pm
