It is currently Sun Sep 21, 2025 7:25 pm
[ 6 posts ] |
GTR 40 18/54 - going from 2 blade to 3 blade issue
PreauxAngler
Having an issues when changing out my prop from the stock 2 blade to the new 3 blade on my 40HP- was told that it was just a simple prop swap and that you use the same factory washer and nut. Problem is the nut wont tighten all the way down without bottoming out. Don’t want to put too much pressure on it and choon something up. Do i need to just keep tightening down on it or do I need to get a new nut?
Fri May 24, 2019 7:38 am |
Wchauvin
 Re: GTR 40 18/54 - going from 2 blade to 3 blade issue
Make sure the prop is seated correctly inside of the hub, if that isn’t the issue, get a new nut. I find the brass ones off the Mercury’s last wayyy long than the junk they sell with gatortail, and they don’t rust. I’ve changed props 100 times on my rig and haven’t had to change the bass nut yet
Fri May 24, 2019 7:46 am |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
It might be too obvious...but is the prop on there the right way? It will seat differently if not put on facing the right direction.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Fri May 24, 2019 8:04 am |
PreauxAngler
Prop is seated properly- it is just slightly thinner than other prop.
Fri May 24, 2019 8:35 am |
PreauxAngler
Fri May 24, 2019 8:37 am |
Wchauvin
The nut from mercury is the same threads, only difference is that it is brass bro. Everything else, including the washer is the same.
Fri May 24, 2019 11:13 am |
[ 6 posts ] |
