It is currently Fri Mar 20, 2026 6:23 pm
Reply to topic  [ 12 posts ]
 Prodrive heads job
Post Prodrive heads job
I had to take my heads off my prodrive because i fucked up the threads where the exhaust bolts on one of them. Upon further inspection i found a big ol crack in that same head, i also cracked the other head where the intake manifold stud screws in. While ive got the heads off im wondering what else should i check and if anyone with better knowledge sees anything wrong with the pictures of my cylinders/ pistons? The pistons are covered in carbon i didnt know if i should clean them or how to clean them.
Tue Jun 11, 2019 10:02 am
Post Re: Prodrive heads job
You'll probably have to replace that cracked head.
I would recommend that you don't try to mess with them too much more.
Seems like every time you mess with it, something gets broken :lol:
Tue Jun 11, 2019 11:18 am
You can grab a new set of stock heads for about 400
Tue Jun 11, 2019 1:34 pm
Wed Jun 12, 2019 4:56 am
“They are seasoned” :lol:
Wed Jun 12, 2019 5:28 am
I've hot a set on the shelf, seasoned. 500 :D
#GhostBoat
Wed Jun 12, 2019 6:44 am
Got*
#GhostBoat
Wed Jun 12, 2019 6:45 am
Wed Jun 12, 2019 2:50 pm
So the blackness of the pistons should jot worry me?
Wed Jun 12, 2019 2:51 pm
Thu Jun 13, 2019 5:15 am
don't worry about that little bit of blackness on the piston, that's normal. them heads crack like yours did over time, I have several just like it laying on the ground in my boatshed. lol just get a new set of heads and slap it back together and go cut some grass, oops, I mean go fishing with your boat.
Fri Jun 14, 2019 9:57 am
cron
