It is currently Mon Mar 30, 2026 11:20 am
[ 5 posts ] |
35 gatortail center console starter trouble
champtd
I have a 35 gtr center console giving me trouble,sometimes it cranks right up , most times it makes one loud click. I put a new starter and same thing.checked battery its ok. Im thinking its the wires going to clutch that ensure its not in gear but Im not familiar how that works. I can tap on it and it starts but I need it fixed,any ideas?
| Mon Oct 28, 2019 9:49 am |
brycecheramie
 Re: 35 gatortail center console starter trouble
I JUST fixed this issue on mines. You have a 12 volt wire running from your key switch to a spade connector on your starter. It is small and sometimes gets frayed. Get you a thicker gauge wire, and replace that old wire with a thicker wire. That is ALL i did and it solved my issue altogether.
| Mon Oct 28, 2019 9:53 am |
brycecheramie
Also, as always, check your connections first. Make sure battery is good, and grounds are tight. But this solved my issue 100%
| Mon Oct 28, 2019 9:56 am |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
You can also check your circuit breaker
Sent from my SM-G975U using Tapatalk
| Tue Oct 29, 2019 7:38 pm |
3rd Coast Killer
Joined: Thu Aug 27, 2009 3:17 pm Posts: 2624 Location: League City, Texas. It's where I play.
I had this problem for awhile. Replaced all of the power wire, Key wire, main wire, everything, still the dreaded click click.
Marcus (maxxis85) on here builds a little relay that you put inline with the starter. Installed almost 3 years ago and have never had the problem sense. Shoot him a PM.
Kool-Aid Brigade
www.southernfowler.com
| Thu Oct 31, 2019 12:57 pm |
[ 5 posts ] |
