It is currently Fri Mar 20, 2026 3:13 am
Reply to topic  [ 7 posts ]
 New Kohler 26.5 EFI RPM question
Post New Kohler 26.5 EFI RPM question
Out of water RPMs- 3750
Just me and some gear -3650
Me and a buddy + dog and gear - 3550
9 x 7 Beavertail Prop
16' Lowe, 74" across the top, (I don't know what that means as far as size goes and I never weighed it) Pictures attached.
I haven't GPS'd speed, does this drop in RPM's seem correct and is there more in the tank if I set it higher? I'd like to get some run time first!
Tue Nov 26, 2019 4:41 pm
Post Re: New Kohler 26.5 EFI RPM question
out of water rpm's seem low to me. maybe 4200 or so. at least on the old carbed 27 knolers it was that way. I put thousands of hours on several of them. great motors.
Tue Nov 26, 2019 8:58 pm
I have a 26.5 Kohler backwater longtail. I goosed the RPMs by buying a longer screw that added more tension to the governor spring. With a hunt load by myself I will run around 4070 to 4120 RPMs. The coils have a preset maximum rpm so there are no worries there by changing the governor spring tension. By far though, I am not the expert. Good luck and I hope this helps..
Thu Nov 28, 2019 3:31 am
Did you get any extra vibration with going that high? I'll try it once I get some hours on this motor.
Thu Nov 28, 2019 5:31 pm
Have been running it that way for about 4 years now with no problems.
Thu Nov 28, 2019 7:47 pm
When you finally get it all worked out, please post back here or PM me with the speeds you are getting. I get about 20 miles per hour with myself and a hunt load. Looks like you have a go-devil. My backwater is mounted on a Gator Trax 1644.
Fri Nov 29, 2019 7:13 am
Yes I will do that
Thanks for the advise
Fri Nov 29, 2019 6:39 pm
