It is currently Tue Jun 04, 2024 5:56 am
Reply to topic  [ 47 posts ]  Go to page 1, 2  Next
 Prop Advice
Post Prop Advice
2016 37 GTR XD all stock on a 16x54 Gator Trax with hunt deck, rod boxes. Heavier than average hunting boat.
I'm looking to get some advice on props. I'm really wanting to get a Hammer Prop, but I'm not sure if I can turn it well enough. Currently using the stock 3 blade. When I've got a light load and its just me, I can get about 25 to 26 mph @ 4000 to 4100 rpms. With a medium load, 22 to 23 mph @ about 3950 rpms. With a heavy load, trudging.
I would really appreciate it if any of you could ask me some questions on what to look for to determine if I would be better off with a different prop.
Weight is everything.
Fri Dec 27, 2019 3:15 pm
Post Re: Prop Advice
Do a leakdown test. Bet your valves are leaking. And no, you cant turn a hammer.
#GhostBoat
Fri Dec 27, 2019 3:59 pm
What RPMs should a 37 xd gtr get? What's its happy range?
Fri Dec 27, 2019 6:07 pm
Should be turning around 4400-4700
Fri Dec 27, 2019 6:28 pm
A stock 37 when propped right should be around maybe 4300. If you prop it to 4700 you're leaving get up and go on the table. Yeah, maybe you get another mph on top, but you lose slow speed planing and load carry. Cup (load) and pitch (speed) both place a load on the engine. You cant have a ton of both with a stock engine. So if maintaining speed with more load matters, then you wont be running 30s with any kind of load.
#GhostBoat
Fri Dec 27, 2019 7:01 pm
A hammer will lug. Run a big blade till you throw a cam and heads on.
Fri Dec 27, 2019 7:40 pm
Big blade has always been the best all around prop for the 2 gtrs I've owned. Hole shot and load wise especially
Sent from my SM-G973U using Tapatalk
HOTSAUCE170 wrote:
Sat Dec 28, 2019 6:15 am
He's running an xd. You're right, but hed have to get whatever adjusted to make it fit because of GT's effort to make their props the only option on the xd.
#GhostBoat
Sat Dec 28, 2019 6:25 am
Sat Dec 28, 2019 7:51 am
Alright, so if Im running 4000 rpms with a medium (normal) hunting load, with the gtr stock 3 blade, what are my options to get to 4300? Are there any dealers that would let me test different props with little or no charge? I just feel like I got cheated since I didnt get the chance to test some different props out when it was brand new. I've been running this set up for 3.5 years. pretty much the same numbers all 3 seasons. My buddy put a hammer on his 37 gtr with no mods and is running 35 with 2 guys and gear. I just cant figure out how mine runs 10 mph less?
Sat Dec 28, 2019 9:04 am
35 with a stock 37 with 2 guys and gear?
#GhostBoat
Sat Dec 28, 2019 9:19 am
Yes, I see him do it all the time. Leave my ass in dust. Hes got the first 37. Its not an XD.
Sat Dec 28, 2019 9:34 am
He keeps trying to talk me into buying the Hammer for mine, but I dont think that it would help me out as much as it did his. Thats why I'm on here to try and figure it out. I just read that BPS will let you return an undamaged prop within 30 days for a full refund minus shipping. I may just order one at a time and see which one performs the best. I just wish that I was given that opportunity from day one.
Sat Dec 28, 2019 9:39 am
I guess I could order both the big blade gtr and the hammer gtr and return the one performs the lease. It looks like my only options for props to fit my XD are the hammer gtr, big blade gtr, raptor hex, and 3 blade hex. These are on the BPS site specific for xd models. I guess I also have the gtr fat blade, but haven't heard too many good things about it. Do yall know of any other prop options/suggestions? Also, I live in Monroe, La. If any of you wouldn't mind letting me borrow your prop and run the river, it would be much appreciated.
Sat Dec 28, 2019 9:49 am
I didn't think a stock 37 had the nuts to turn a hammer prop.
And 35mph with 2 guys and gear?
Hmmmmm
Sat Dec 28, 2019 9:50 am
Yep, I think his boat is a 16X44 or 50 with hunt deck. Very basic/light boat, empty hull with front deck, floor, and boxes in the back. No rod boxes. He just turned it into a center console too.
Sat Dec 28, 2019 9:56 am
I don’t believe 35 with a stock 37. I would need to see that in video on gps (not phone speeds) and then have to know what all has been done to his hull
Sat Dec 28, 2019 5:53 pm
Post Prop Advice
Yup. Throwing a flag on that. Been around these boats quite a while and really struggle with that.
Sat Dec 28, 2019 7:13 pm
Yeah no way he is running that. Dude is fibbing to you bud. No way he is running 35. If he is, I need a video
Sat Dec 28, 2019 9:16 pm
If he walks the dog on you running side by side, I don't think just a prop will help you, unless yours is worn.
Also, he may be doing 30-31 and you're running 25-26.
I wouldn't go out and say 35 mph stock tho….
Sun Dec 29, 2019 6:20 am
Are you trimming all the way up? Which hole is your motor on?
Your friend is lying to you, no stock motor turns a hammer for starters, and DEFINITELY does not run 35 mph.
Sun Dec 29, 2019 8:17 am
Sun Dec 29, 2019 2:48 pm
Sun Dec 29, 2019 2:52 pm
Also, I've tried to run with the pin on the lowest hole and the second from the bottom, and I cant trim up enough when I'm on plane. It bottoms out before I get to the sweet spot. So that's why I was considering a jack plate.
Sun Dec 29, 2019 2:57 pm
No way he is running 35 stock much less 38. If he thinks he runs that fast tell him I want to race him for cash
Sun Dec 29, 2019 3:00 pm
Sun Dec 29, 2019 3:49 pm
Bryce, if he is confident in those numbers for real, he should race me for cash lol
Sun Dec 29, 2019 5:33 pm
This is priceless. There’s no way in hell.
Sun Dec 29, 2019 7:27 pm
Haha, yall are killing me. I'll double check his numbers next time I see him and maybe get a video for you non believers...haha
Regardless, I'm on here to get advice for my boat. He doesn't need help, I do. Back on the jackplate. If I cant put my motor pin on either of the upper two holes, doesn't that mean I should lift the motor up some? I understand that too much down angle on the shaft would be bad. But I feel like mine might have too much up angle on it. Are we still a hard no on the idea of a jackplate?
Sun Dec 29, 2019 8:10 pm
Also, his boat is a 16x48 Go Devil.
Sun Dec 29, 2019 8:19 pm
Post Prop Advice
You will get as many people here to endorse a jack plate as will believe your buddy’s unmodded speeds.
Unless your transom is way off and is causing performance issues, the most likely culprit of lost power is leaking valves as Russ said in post #2.
Sun Dec 29, 2019 8:43 pm
Sun Dec 29, 2019 9:04 pm
Sun Dec 29, 2019 9:20 pm
Sun Dec 29, 2019 10:38 pm
Mon Dec 30, 2019 3:19 am
Okay, your buddy aside (even though his speeds are BS :lol: )
You say you cant put it in the top 2 holes. Why not? I may have missed that.
Also, Im willing to put my paycheck on these 2 things.
Leaking valves and Prop wear. Measure your prop, even if you are missing the slightest bit, you are missing out on performance.
Also, those GatorTrax boats are NOT speed demons by any means.
And round chines are a little slower too.
Mon Dec 30, 2019 6:57 am
Mon Dec 30, 2019 8:13 am
He lives within 20 miles of me. We'll get it figured when we both have a little time.
#GhostBoat
Mon Dec 30, 2019 8:26 am
I doubt prop wear because RPMs are low but that may be a contributor after really leaky valves
Mon Dec 30, 2019 8:31 am
Mon Dec 30, 2019 9:12 am
Users browsing this forum: No registered users and 43 guests
