It is currently Tue Mar 17, 2026 8:47 pm
Reply to topic  [ 14 posts ]
 Bolting governor hole question
Post Bolting governor hole question
I have a 1/2 13 tap that I'm going to use to thread the hole for the governor. It seems to be about the correct size. My question is, besides loctite should I use some RTV at the shoulder of the bolt? Also, is there anything else I should know?
Wed Jan 08, 2020 4:49 pm
Post Re: Bolting governor hole question
No need to tap it, most just put a bolt through it with a nut and lock washer or nylon lock nut and washer with rvt. But, it you going to tap, yes, just rvt sealant should work.
Sent from my Pixel 2 using Tapatalk
Wed Jan 08, 2020 5:46 pm
I've seen it both ways. I figured tapping it would prevent the risk (although slight) of the nut getting loose.
Wed Jan 08, 2020 6:43 pm
Just cut the flipper off the shaft and stick the shaft back in.
Thu Jan 09, 2020 9:53 am
Thu Jan 09, 2020 10:08 am
Thu Jan 09, 2020 1:53 pm
Thu Jan 09, 2020 3:58 pm
Make sure you take the governor gear out of the inside of the block when you’re in there.
Thu Jan 09, 2020 3:59 pm
I just left the paddle shaft with the keeper clips inside and out. Cut the paddle off so it's a straight shaft and pull the governor stuff out of the inside of the engine. Been working fine on my time bomb.
Thu Jan 09, 2020 4:23 pm
Fri Jan 10, 2020 6:00 am
Pull it. You'll notice when you have it apart the gov gear and the weights just pop right off with a bit of pressure. Maybe use a screwdriver to pry it off.
Fri Jan 10, 2020 6:18 am
There we go. It is off. It faught it and faught it and then all of a sudden slid off with ease.
I saw a video on line where it lifted off pretty easy, but mine took a little bit more effort. Not being familiar with it I didn't want to force it.
Fri Jan 10, 2020 6:55 am
If it’s a 35 but no mikuni, be prepared to put on an additional spring that didn’t come on the stock carb and throttle assembly.
Fri Jan 10, 2020 8:09 am
Fri Jan 10, 2020 9:01 am
