It is currently Wed Apr 08, 2026 8:00 am
Reply to topic  [ 9 posts ]
 Performance Heads with Stock Carb/Exhaust
Post Performance Heads with Stock Carb/Exhaust
I am running a 35 Briggs and after a leakdown test, it is time for a valve job (also had blown head gasket). Since I am already pulling the heads, I figure I might as well get away from the Briggs valves and do a little upgrade. I ordered some Delta Performance heads.
I plan on still running stock carb and exhaust. Anyone see any issues? I will retune the carb after everything is set.
More power sounds great with new carb and exhaust, I just didnt want to spend $1200-1300 on it if its not "needed".
Wed Sep 23, 2020 6:43 am
Post Re: Performance Heads with Stock Carb/Exhaust
No issues, but for ~$300 more you can throw in a performance cam and really be making a difference.
Wed Sep 23, 2020 7:06 am
Opinions will vary on this but i say u will need to jet the carb
Wed Sep 23, 2020 10:21 am
Lies. Don't listen to Will C. He knows nothing.
Or does he.........?
Seriously, though, he's probably right.
#mudmotor>physics
Wed Sep 23, 2020 11:12 am
So, I went with new heads from Will, and originally used a stock carb and exhaust. It Definitely made a difference but I quickly bought a mikuni and exhaust and the motor WOKE UP
I'm talking significantly different from just stock, and stock with heads.
If youre going to do it, do it all.
It costs a bit to get it done, but you'll love it.
Sent from my SM-G960W using Tapatalk
B. MacDonald
Mon Sep 28, 2020 3:33 am
Thanks for the feedback guys. I started with just heads, then was talked into carb last week, and now I think I have been talked into exhaust. Looks like I will order a Stainless Works exhaust this morning.
I guess it hurts less if you buy it all separate!
Mon Sep 28, 2020 6:56 am
Mon Sep 28, 2020 8:34 am
Yeah I am doing the work myself and I was trying to keep it simple this go around with things I am familiar with. But if I get the itch later on I will tear into internals and put a new cam in.
Mon Sep 28, 2020 2:57 pm
Mon Sep 28, 2020 3:20 pm
