It is currently Tue Apr 07, 2026 9:13 am
Reply to topic  [ 5 posts ]
 smaller sd prop on lt
Post smaller sd prop on lt
Hey guys I had a 29 kawi MB hyper. I sold that and currently own a 16 godevil lt. I am wondering if the prop from the kawi which is a 9 in prop would work on the go devil. The kawi was threaded shaft. I don't know if they are the same threads. Or if it will swing it.
Tue Apr 06, 2010 8:08 pm
Post Re: smaller sd prop on lt
all depends on what size prop is it 9x?? and most likely it will be way to big for ue lt
BUNDY BUILT SKIFFLESS
cuz der bad ass like dat....
bunnny rabbit customs.
Tue Apr 06, 2010 8:10 pm
16 lt slings a 9x4 prop. not sure what the 29 uses. propably a lot more pitch. not sure if it will work or not but the 16 shaft is 3/4x10 thread i believe. i think the 29 uses a 7/8 shaft
ETD88 09/28/09-05/14/2010...
you are correct sir the threads dont work. So I will need a prop you say 9x4? Also has anyone changed the throttle to a sqeeze with spring return? and would this jack anything up?
Tue Apr 06, 2010 8:30 pm
Yep, 9x4 for the 16 according to GD website. never tried the throttle.
Wed Apr 07, 2010 8:16 am
