It is currently Tue Mar 24, 2026 6:46 pm
Reply to topic  [ 6 posts ]
 2015 Gtr 35 mikuni/e-pump install ?
Post 2015 Gtr 35 mikuni/e-pump install ?
Just received my carb kit and and exhaust from Delta. Delta said I didn't have to but recommended that I run an E-pump. Any of you guys have some insight or any pics of how you mounted your E-pump to the motor??
Thu Oct 12, 2017 11:43 am
Post Re: 2015 Gtr 35 mikuni/e-pump install ?
I run mine 6-12" from the gas tank through (currently) 8' of fuel line to the engine. I was running about 15', but it was time to put new line on and didn't use as much. It's not vibrating with the engine with it in the boat.
#TheGhostBoat
Thu Oct 12, 2017 11:47 am
Ok thanks. So you did you bypass your manual pump all togheter or leave it inline. May be a dumb question but I'm new to do any mods on these motors.
I see a lot of guys say you don't need to run an e-pump
But I got it so I figured I would give it a shot
Thu Oct 12, 2017 12:09 pm
Never had a stock pump installed. Built this engine from a parts engine and some aftermarket additions myself.
#TheGhostBoat
Thu Oct 12, 2017 12:31 pm
if your stock fuel pump is working fine, You will be fine.
Fri Oct 13, 2017 6:01 am
I got 12-15 ft of fuel line(5/16), impulse type pump, tank built in to console, primer bulb and fuel filter within the 1st 2 ft., works good for me, and I am running a mikuni carb. with 3/8 line in my other boat had issues kept losing prime at low speeds.
Fri Oct 13, 2017 8:01 am
