It is currently Sat Mar 28, 2026 2:37 am
Reply to topic  [ 28 posts ]
 boat bottom surface
Post boat bottom surface
If you don't coat the bottom of the boat with slick stuff, are most people leaving it bare aluminum or just painting body color?
1854 CC backyard build with GTR 37 EFI
Build thread here.. viewtopic.php?f=4&t=66815
Mon Apr 11, 2016 12:46 pm
Post Re: boat bottom surface
most I've seen are at least painted the boat color.
Mon Apr 11, 2016 12:53 pm
yea that's kinda what I was thinking. I might do gator glide in the future so I was trying to avoid having to sand it when the time comes. I might just just do it now while I'm working on it. I don't really need gator glide but everyone on here seems to really think it helps. The only thing I think it might help me with is pushing the boat over beaver dams that I don't want to hit at speed.
Mon Apr 11, 2016 1:13 pm
Mon Apr 11, 2016 1:21 pm
Regular paint is way slicker than bare aluminum when wet. If you aren't going to do GG, then go ahead and paint it if you run a lot of veg and grass. Just my .02. If it was mine I'd go ahead and gator glide it. It is most definitely worth it.
1854 Prodigy DPE Level 3 HDR
Mon Apr 11, 2016 1:38 pm
Does bare aluminum slow the boat down in water or only mud and veggies?
Mon Apr 11, 2016 1:40 pm
Mon Apr 11, 2016 2:03 pm
you will gain no speeds with GG, I know I didn't. It does however aid in launching your hull, running any vegetation or muck. Before I had GG, when I hit a Lillie patch on our lease, it was like slamming on the brakes. Now, I have to be careful, because you can hit a grass patch, and slide 75 yards across that sucker. I applied GG to my sanded down bare hull. I have however seen it added to a painted hull too.
Tue Apr 12, 2016 4:36 am
Ok so now the question is, gg first or boat paint first? I'll mask either way. I'm assuming boat paint first and just keep the masking in place for where the gg will go, but you know what they say about assuming...
Tue Apr 12, 2016 4:48 am
Some would say use a real good aircraft aluminum etching primer before I would say rough up the bare aluminum and just put gg on it
23 COPPERHEAD
PUSHING A MODIFIED TRACKER 1542
Tue Apr 12, 2016 4:55 am
I sanded mine down, then wiped with acetone. Put the GG on the bare hull. Then painted hull around the GG
Tue Apr 12, 2016 5:26 am
http://mudmotortalk.com/mmt_v2/viewtopi ... =2&t=21516
Tue Apr 12, 2016 6:17 am
Sweet, thanks.
Tue Apr 12, 2016 6:46 am
how big is the boat?
http://www.gatorglide.com/
gatorheads@comcast.net
Tue Apr 12, 2016 9:50 am
I did my 1754 gator tax which is actually 18' 8"x54 with 1/2 gallon kit of base and glide. Still had plenty left over for a touch up coat or 2 in the future. You are supposed to put it on thin and it will go a long way if you do.
Tue Apr 12, 2016 10:11 am
Frog, what is the difference in G2 and G4?
Tue Apr 12, 2016 10:18 am
Tue Apr 12, 2016 10:49 am
From personal experience, go with the G2, it seemed much more than 10% more slick to me.
Tue Apr 12, 2016 11:30 am
10-4, thanks for the replies.
Tue Apr 12, 2016 12:19 pm
1854 ...I ordered the g2 1/2 gal
Tue Apr 12, 2016 1:20 pm
Will masking tape stick to the gator Glide
Tue Apr 12, 2016 2:21 pm
Tue Apr 12, 2016 3:21 pm
You'd be better off painting, then do GG.
GG is similar to a non stick Teflon cooking skillet. Haha
Tue Apr 12, 2016 5:43 pm
Yea that's what I think I'll do. Now I just need to convince some of my friends to come help me in the next weekend or two...
Tue Apr 12, 2016 5:54 pm
Wed Apr 13, 2016 10:00 am
Wed Apr 13, 2016 10:34 am
Thu Apr 14, 2016 5:03 am
I actually taped off the hull approx. 1/2" above the gatorglide. then applied another layer to that tape then to some drop cloth. painted the whole hull, then came back with a scrap piece of aluminum and held it on the gatotglide line. Sprayed the area where the tape was and it blended it. Cant tell.
Wed Apr 20, 2016 1:37 pm
