It is currently Tue Mar 24, 2026 10:05 am
[ 5 posts ] |
BEST BOAT SIZE PERFORMANCE WITH 23 MB
kwight
Im trying to figure out what size hull I need to go with for my 23 mudbuddy. Ive been told that because of the weight of it, I need to go with a little wider hull like a 1652. I was originally going to go with a 1544 or 1644 but was told by a boat dealer that I would lose performance due to the weight causing too much draft. Just curious as to what I need to do. This will be a one man rig for the most part with a light load.
| Tue May 03, 2016 12:45 pm |
HOTSAUCE170
Joined: Thu Jun 05, 2014 11:44 am Posts: 1685 Location: Lake Blackshear,GA
 Re: BEST BOAT SIZE PERFORMANCE WITH 23 MB
16/44 or 17/44
Sent from denda this
_________________ I named my boat RIANNA cause it gets beat up all the time
| Tue May 03, 2016 1:19 pm |
dwalks95
I have a 648 (1648) war eagle with a 23 hp mud buddy SD. no problems with weight, im trying to figure out if i can handle a 35 mud buddy SD. 1644 would be good, 1544 im not to sure of. works well for me overall depending the application. extreme shallows and thick mud are a little sketchy (not sure if hull or motor problem) and can get stuck easily. but if theres 4 inches of water im good. ive ran the boat by myself and the boat was pretty much empty and ive never had a problem with water over the transom.
_________________ 2014 648 War Eagle w/ 23hp Mud Buddy SD
| Fri May 06, 2016 10:33 am |
Will
A 1744-1748 crawfish skiff would be good, it has the length to counter the weight, yet still small foot print for drag on step.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Fri May 06, 2016 10:37 am |
koonce727
Joined: Sat Dec 04, 2010 7:19 pm Posts: 106 Location: Mergens Point, WI
I have a 23 copperhead on a 1536 scully skiff. Boat flys, but if I were to do it again I would go in that 40-44 range for width and another foot or 2 longer. I call that little boat the death wagon for a reason.
_________________ Burlap Brothers
| Fri May 06, 2016 12:18 pm |
[ 5 posts ] |
