It is currently Tue Mar 17, 2026 10:00 pm
Reply to topic  [ 24 posts ]
 good portable gas tank
Post good portable gas tank
Need a good new portable gas tank! My old Tempo is kaput. Was pretty good but now cannot find that brand locally. Moeller has bad reviews- bad threads and no vented cap! Would like to buy from someone other than BPS. Any suggestions?
Fri May 13, 2016 6:47 am
Post Re: good portable gas tank
Probably going to have to mod whatever tank you get, vent etc... gov has phucked them all up
http://www.gatorglide.com/
gatorheads@comcast.net
Fri May 13, 2016 7:17 am
Yep, the EPA has regulated all fuel storage containers. I've ditched two 6gal plastic tanks in my boat and have since had a 17gal aluminum tank built to go under the deck with a plain ol vented cap. Works like a charm, no more leaks, no more red balloon fuel tanks. Spent $120 between the two plastic tanks and they're garbage. I considered using a plastic fuel cell for like a race car etc but I never could find exactly what I wanted, look at Jegs and Summit, maybe you'll have better luck.
-Custom pool noodle
-stage 4 water wings
Fri May 13, 2016 7:29 am
That sucks! The six gallon is more than enough for me, rather carry more beer than gas... :mrgreen:
Fri May 13, 2016 7:58 am
Can you buy vented caps? Mine is in my garage and still blows up in the Florida heat. Anybody here do the kids and have good luck?
Tue May 17, 2016 4:51 pm
My tank did that same thing brand new from bass pro. Only solution I found was to drill out the cap. Workes perfect now.
Tue May 17, 2016 6:03 pm
Can also install a small petcock valve somewhere on the tank.
Tue May 17, 2016 6:24 pm
I just added another 6.5 moeller to my rig. Ive had them on the current and last boats with no complaints.
Tue May 17, 2016 6:34 pm
That sound bar...you shouldn't have posted this.
My wallet just shuddered a little.
Thu May 19, 2016 11:06 am
Thu May 19, 2016 1:59 pm
My Moellers are sitting in the back of the shed..... Where they will most likely stay. I replaced them with this...
-Custom pool noodle
Thu May 19, 2016 3:58 pm
I haven't taken a good finished pic yet but this is with it painted up and under the deck, before I laid the turf back down. Holds about 17gal.
-Custom pool noodle
Thu May 19, 2016 4:02 pm
Hear is a picture of a built in tank, we custom fitted to front deck on my Alumacraft Jon.
Fri May 20, 2016 2:42 pm
go look at Northern Tool catalog.
alum 13 gal tank is like 180$ 18 gal is another 50$ i run these in several boats.
Fri May 20, 2016 7:21 pm
Fri May 20, 2016 7:57 pm
Fri May 20, 2016 8:01 pm
Marine Connection in Ft. Pierce
Fri May 20, 2016 8:17 pm
It takes about 2 minutes and a pair of needle nose pliers to gut the innards of that cap and you'll never have another problem. PM me a picture of the underside of the cap and if it's the same I'll send you a photo of what mine now looks like. I had to do the same thing to my buddy's.
If your tank balloons hard enough the pressure can put a pinhole in your fuel bulb and then you can chase that problem down, too.
Aluminum tanks have their own issues. When it gets cold, the air in the tank will form condensation inside the tank walls and then you get water in your fuel as soon as you slosh it around a bit on the way to the ramp. Over time (a long time, generally) that condensation will cause corrosion and pinhole the tank from the inside out.
Sun May 22, 2016 1:34 pm
Is that a quick disconnect fitting on there? Who makes it? That looks slick.
17/54 gator Trax 35 mudbuddy... mostly stock
Sun May 22, 2016 6:21 pm
The QD fittings are awesome if you want to change tanks like he is, and I tried it but every one I've ever had has worked for a while and then failed.
Sun May 22, 2016 7:32 pm
Ive had this one 6 months no issues, had same tank setup on my old rig and didnt have issues with it either.
Sun May 22, 2016 7:59 pm
Which ones are they? Where did you get them?
Sun May 22, 2016 9:36 pm
Mon May 23, 2016 8:53 am
Its what gt uses, they can be found at academy.
Mon May 23, 2016 10:56 am
cron
