It is currently Fri Mar 20, 2026 7:08 am
Reply to topic  [ 13 posts ]
 Floor removal
Post Floor removal
I have a lowe 1752 Roughneck and i want to remove the floor to take out the wet foam. i am having a problem trying to figure out how to remove the floor and the panels that line the gunwall. i was wondering if anyone here has done it before or has any tips on how to do it the most painless way if there is any. thanks in advance
Thu Jun 23, 2016 5:45 pm
Post Re: Floor removal
Post up a pic I'm good at takin shit apart!
Sent from denda this
Thu Jun 23, 2016 7:33 pm
okay i will have to post a picture tomorrow, i am at work and work 24hr shifts
Fri Jun 24, 2016 7:29 am
Is the floor riveted, crimped, or welded in?
Fri Jun 24, 2016 8:13 am
the floor is riveted in and the side panels are riveted at the middle and bottom and welded at the top in three spots. i tried to drill the rivets out in one of the side panels but am having a hard time drilling them out compared to other rivets that i have done in the past
Fri Jun 24, 2016 9:12 am
Use a grinder
Fri Jun 24, 2016 10:10 am
Get a new bit.
Sent from my SAMSUNG-SM-G925A using Tapatalk
Fri Jun 24, 2016 11:34 am
What msm said. Your bit must be dull. Drilling them out should be quick and easy. Then hit the welds with a grinder.
Fri Jun 24, 2016 1:06 pm
the bit set i have it new, the problem is these rivets still have part of the shaft sticking out that normally breaks off and leaves the indent
Fri Jun 24, 2016 1:07 pm
Tip them with a punch then drill it out. They aren't hard to drill out until you break a bit off in one so be careful.
Fri Jun 24, 2016 1:25 pm
What rooster said. I had to do that with a few. If that doesn't work (which it should) hit them with the grinder.
Fri Jun 24, 2016 2:48 pm
Ever do this? Pics?
Support the troops. We support you.
B. MacDonald
B. MacDonald
Tue Jul 26, 2016 5:20 pm
No with work and family stuff I never got around to pulling it. I will more than likely do it after this season ends
Tue Jul 26, 2016 9:21 pm
