It is currently Wed Mar 18, 2026 5:27 am
Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
 Removing Foam
Post Removing Foam
Debating on removing the foam from under the front deck. 2009 1650 gator trax, wondering if the foam provides any structural support to the deck, i'm hoping to mount a winch below the front deck and gain some extra storage area. Has anyone done this?
Thanks in advance
Fri Jun 17, 2016 11:48 am
Post Re: Removing Foam
The foam does not provide any structural support. Lots of people have removed foam. Search for Excel/Go Devil foam removals.
Fri Jun 17, 2016 12:14 pm
Use the search feature, plenty of topics identical to this one. Foam is for flotation not support
Fri Jun 17, 2016 12:15 pm
Searched, lots of good info. Thanks for the tip, will remove the foam under the bow tomorrow. I did not return any results on removal of foam from the hunt deck....would be nice to know if anyone has gone that route and if they cut into the false transom or the top of the deck.
Thanks again.
Fri Jun 17, 2016 1:42 pm
Is your foam waterlogged?
Fri Jun 17, 2016 2:00 pm
Mon Jun 20, 2016 5:22 am
Mon Jun 20, 2016 5:18 pm
Got all the foam out from under the bow, a small portion was water logged. Used a pressure washer and it made a hell of a mess, but was totally worth it. Removing the false transom this week and will blast all the foam out, the previous owner had a transducer on the stern and a small random hole below the waterline, i'm sure its water logged. Also yanking the foam out from under the floors which i KNOW are full of water. Thanks for the tips, will post updates.
Ducknut, do you have any photos of the crossmembers inside the huntdeck, my hull is an 09 GTrax.
Thanks in advance
Wed Jun 29, 2016 2:27 pm
This has turned into more of a rebuild than just a foam removal, here are some of the progress pictures. the floor and front deck were all hydroturfed, I spent about 4 hours with a wire wheel removing it so i could drill out the rivits to pull the floors. Lots of work ahead.
Sat Jul 09, 2016 6:54 pm
What is the fascination with removing foam? How much weight does waterlogged foam really add? 10 -15 lbs total maybe? Seems like a ShitTon of work for very little effect.
17/54 gator Trax 35 mudbuddy... mostly stock
Thu Jul 28, 2016 7:58 am
depending on the boat waterlogged foam can add up in weight quick. I pulled the floor up in mine and had around 60lbs of waterlogged foam so getting it out just adds to performance.
Thu Jul 28, 2016 8:08 am
Thu Jul 28, 2016 8:11 am
Thu Jul 28, 2016 9:04 am
Thu Jul 28, 2016 9:06 am
Welds
Thu Jul 28, 2016 12:31 pm
Thu Jul 28, 2016 12:33 pm
Yup why I ain't done it lol. Just need to sell hull
Thu Jul 28, 2016 12:42 pm
and screw the next guy :O
Thu Jul 28, 2016 12:58 pm
Post Removing Foam
Haha maybe he'd be more motivated then me :lol:
Thu Jul 28, 2016 5:53 pm
Here a few updated photos. I've spent a fair amount of time patching all of the random drill holes in the boat from the previous owner. The winch mount is complete and the hawse will have the final weld done today. The mock up rigging will be next, then floors and seat will be re-installed, off to media blasting then paint. If anyone knows of anyone that (professionally) applies gator glide in the N. Fla area, i would appreciate the referral. Will update pictures as more progress happens.
Tue Aug 02, 2016 8:34 am
Took 280# out of my buddies go devil boat. Depends on how waterlogged it is. Couldn't step 3 guys now the thing gets on step no problems. Told him I removed his invisible fat ass friend.
Tue Aug 02, 2016 12:07 pm
Tue Aug 02, 2016 1:55 pm
Tue Aug 02, 2016 6:15 pm
Tue Aug 02, 2016 7:21 pm
Tue Aug 02, 2016 7:32 pm
Tue Aug 02, 2016 7:34 pm
Post Removing Foam
Is it really worth it is what I struggle with. It looks to be a royal pain to remove the welded floor. To save what? 80lbs? Basically a trolling motor battery?
Tue Aug 02, 2016 7:59 pm
[quote="mudxxed"]Is it really worth it is what I struggle with. It looks to be a royal pain to remove the welded floor. To save what? 80lbs? Basically a trolling motor battery?[/]
What's your speed with just you and a gas tank in the boat?
Tue Aug 02, 2016 8:01 pm
32-33
Tue Aug 02, 2016 8:02 pm
Tue Aug 02, 2016 8:03 pm
Its always wet by the drain plug, its an 07 Excel made by Rivertrail in Arkansas. One of the last before the tornado. Ive stepped on the floor and heard it squish. Its def got water in it, just not sure how much.
Tue Aug 02, 2016 8:08 pm
Post Removing Foam
Tue Aug 02, 2016 8:23 pm
not sure, it don't get that cold here :lol:
Tue Aug 02, 2016 8:25 pm
Tue Aug 02, 2016 8:37 pm
Tue Aug 02, 2016 8:46 pm
Tue Aug 02, 2016 8:47 pm
Handheld gps on video of those speeds
Or come to blackshear this weekend and if you outrun me I'll pay you gas here and back!
Sent from denda this
Tue Aug 02, 2016 8:50 pm
When you passed me and Jd145 who has the delta efi maybe we weren't running wide open?? Or were we come find out
And if you scared go to church!
Tue Aug 02, 2016 8:54 pm
Huh?
Tue Aug 02, 2016 8:56 pm
