It is currently Tue Mar 17, 2026 2:51 pm
Reply to topic  [ 27 posts ]
 hull protection
Post hull protection
any of you guys thought of this to protect your hull?
https://www.youtube.com/watch?v=tNA17cvUMIA
its a spray on poly covered with a slick.
Mon Jan 02, 2017 11:18 am
Post Re: hull protection
looks really cool! My concerns would be adhesion, touch up, weight. But number one adhesion especially when it gets nicked then the hydraulic effect of the water . Like to see some testing.
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Jan 02, 2017 12:14 pm
Frog, have you ever tested your GG over a smooth bed liner like Durabak Smooth? how is the adhesion?
Mon Jan 02, 2017 2:56 pm
Mon Jan 02, 2017 6:23 pm
Mon Jan 02, 2017 6:25 pm
$33.00 per s/f=average cost of doing a boat is $3000.00! :o
I'll stick with a proven system, Gator Glide thanks ............... :roll: :roll:
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Tue Jan 03, 2017 5:54 am
Tue Jan 03, 2017 10:19 am
Tue Jan 03, 2017 1:15 pm
I wouldn't pay 3k. I'm thinking more of applying a 1/16" lay of liner and GG over the top of that, flipping the boat and doing it myself.... would give durability and slick.
I want the liner bc the water is a sheet rock river. has some shelves with sharper edges that like to make gouges in a hull. figure the liner will turn a gouge to a dent and the dents to non-issues. then the GG would keep it all slick.
obviously if I square up to a sharp edge the hull is taking the impact, but for the other instances this would work. I mean if the jet boat guys are using this method it must be the way to go. They put their rigs through the roughest elements possible.
Tue Jan 03, 2017 1:27 pm
Tue Jan 03, 2017 1:45 pm
Tue Jan 03, 2017 7:41 pm
IMO only: If I was running a rocky river a majority of the time, i'd add uhmw to the bottom and be done worrying about it. It is a ton of work to drill and attach it to the hull, but worth every minute spent, because nothing will protect your bottom like a 3/16 or 1/4 piece of slippery plastic. If your boat has ribs and is not a true mud hull add it to the ribs.
It sounds like you plan to flip the boat and do it yourself anyway, so as long as you have it flipped over start drilling holes and mount the uhmw sheet and never regret it.
1854 Prodigy Open
HDR/Stage 3 mods
Wed Jan 04, 2017 5:44 am
Wed Jan 04, 2017 9:07 am
Wed Jan 04, 2017 2:15 pm
Wed Jan 04, 2017 2:19 pm
1854 Prodigy Open
HDR/Stage 3 mods
Thu Jan 05, 2017 5:49 am
Thu Jan 05, 2017 8:42 am
EVT used to do the poly bottoms with 3m 5200 as the adhesive.
Thu Jan 05, 2017 4:03 pm
I was watching the GG videos and this popped up on the side, wondered if ya had ever seen this? I know some of ya have talked about drilling it to the bottom of the boat, but what about applying it this way?
https://youtu.be/LCYDsCs8g28
They had a couple other videos too about prepping aluminum and on curved surfaces
Fri Jan 06, 2017 6:04 pm
That looks like a vacuum seal poly???
Sat Jan 07, 2017 3:06 pm
Sun Jan 08, 2017 6:41 pm
I have done it. It's only a .125 thick the oysters really tear it up had it on the boat for two years. But it got so shredded it started slowing the hull down so I ripped it off. The install is a PIA bc the sheets only come 18" wide so lots of taping and cutting. before the vacum process.
Tue Jan 10, 2017 12:17 pm
would you do it again or go a different route now that you know?
Tue Jan 10, 2017 2:36 pm
just ran across this..
Toledo bend fiberglass does it, they call it gorilla hull. I thought it was only for bass boats and then I saw this. Was reading a fishing page where someone asked about fiberglass repair and a ton of people recommended this "gorilla hull " .. I may give them a ring and see what this is all about
Tue Jan 10, 2017 6:37 pm
Tue Jan 10, 2017 9:36 pm
Wed Jan 11, 2017 9:09 am
Frog, Any change you plan on seeing if GG can stick on some smooth roll-on bed liner? Id like to give you the business but want to make sure it will adhere.
Wed Jan 11, 2017 3:18 pm
