It is currently Tue Mar 17, 2026 2:21 pm
Reply to topic  [ 31 posts ]
 Binnacle with trim on handle
Post Binnacle with trim on handle
My CC prodrive has the trim switch located on the dash in front of the binnacle which isn't the easiest to operate the throttle and trim at the same time. Has anyone ever installed a top mount binnacle that has the trim switch located on the handle?
Current setup:
Like this:
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Thu Feb 27, 2014 8:52 am
Post Re: Binnacle with trim on handle
I sure wish they offered this!
Sent using Morse Code from my not so smart phone.
Thu Feb 27, 2014 9:07 am
To my knowledge, nobody makes a box with throttle only that has a trim switch built into the handle.
On the binnacle box in your second pic, about 1/2 the travel of the throttle lever/handle is for throttle and the other 1/2 of travel for shift (for an outboard). So, if you dont mind having a "dead spot" when you move the handle back and forth (because you wont be using the shift capabilies of that box), then yes it will work just fine.
Thu Feb 27, 2014 9:11 am
I could be wrong, but I'm pretty sure it will throttle up as you move the handle all the way back also..
Thu Feb 27, 2014 9:19 am
Sounds like something you ought to build boatdr. I would buy one for mine!
Sent from my beeper
Sent from my beeper
Thu Feb 27, 2014 9:32 am
Thu Feb 27, 2014 9:45 am
I looked into one for mine and found one that only has forward like the ones we got and has trim built in but was $350 compared to the $50 throttle we have
Thu Feb 27, 2014 9:52 am
I didn't know if there was a cost effective option. Guess I'm on to the drawing board to see what I can come up with
"The internet"
Thu Feb 27, 2014 11:11 am
We talked about working something up. Where the plate screws to top of throttle put switch in it.
Thu Feb 27, 2014 11:12 am
Or remaking top handle with trim in it
Thu Feb 27, 2014 11:13 am
Thu Feb 27, 2014 11:22 am
Thu Feb 27, 2014 11:26 am
Thu Feb 27, 2014 12:18 pm
Thu Feb 27, 2014 12:23 pm
1754 GTB / 35 GTR
Thu Feb 27, 2014 12:56 pm
I saw the rig. I didn't look too close at the pix. Gonna have to go back and look!
Thu Feb 27, 2014 1:25 pm
had a blinker trim on my old bass boat. worked great.
Thu Feb 27, 2014 1:34 pm
The excel had a quicksilver box
16x42 Charles Leonard ... Sold
18x46 Gator Tail w/ 35 gtr stage 1 by hoyt
Thu Feb 27, 2014 2:04 pm
That makes sense...it had the Mercury LU, trim and shift mechanism.
Thu Feb 27, 2014 2:24 pm
I just looked at the pictures, closer. Looks like the Sport V doesn't have the electric clutch. So, the control probably works/acts just like the outboard control. Center neutral, reverse back, forward front. Two cables; one for shifting, one for throttle.
Thu Feb 27, 2014 3:55 pm
Thu Feb 27, 2014 4:12 pm
X2
Thu Feb 27, 2014 9:32 pm
Same subject diffrent app but I finally got my trim switch working!
Thu Feb 27, 2014 9:47 pm
Lookin good
Thu Feb 27, 2014 11:53 pm
when they gonna be public ready?
Sent from an Apple Tree..
Fri Feb 28, 2014 1:31 am
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Tue Mar 04, 2014 7:45 am
Had to bring this up again. Gatortail is using a binnacle with forward reverse and the trim switch on the new 37efi cc rigs. Is it the same for a stock 35 carbed and what brand is it? Looks like a mercury unit anyone know which make, mottle etc.. ?
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Feb 13, 2017 1:53 pm
It is a Mercury....& high $$.
Mon Feb 13, 2017 2:56 pm
Tue Feb 14, 2017 8:20 am
For around $30(Bass Pro Shop) you can add a floor switch to your trim circuit, my biggest problem is remembering that it is there. but it does free up your hands 1 for steering, 1 for throttle and right foot for trim!!!
Tue Feb 14, 2017 8:54 am
