It is currently Tue Mar 17, 2026 10:02 pm
Reply to topic  [ 14 posts ]
 CC mud boat question
Post CC mud boat question
Ok so I am going to have a guy build me a boat in April time frame. I hunt in restricted hp areas so I'm going with a 25 big block w/reverse . I do not hunt a lot of vegetation or tight spots . I am going to use this boat for duck hunting and wade fishing both. I was origanlly going to go 1648 including the hunt deck. I have this idea now on how a small center console like gtr tail uses would be in a boat like this . I know it's a smaller boat . What do yall think ? What's the smallest size boat yall would ever put a real small center console in . If I did go center console would yall keep it a 1648 or change size up . I do plan on doing some mods to this motor later . Thanks for any input .
Fri Feb 17, 2017 2:53 pm
Post Re: CC mud boat question
That motor is the same block as the 37, which is heavy. Longer boat will help offset the weight. I personally would not go less than 17 for sure, and would go longer if possible.
Fri Feb 17, 2017 2:58 pm
I had a 16x48 CC 36 Prodrive.
I loved it. But it was a little short and a little narrow. I also had a custom CC made and it was wider than normal.
But it was a fast boat and easy to make long runs.
Fri Feb 17, 2017 3:03 pm
I have talked to lots of people, and after discussion my 25 BB is being put on a 1748 GTR extreme series as we speak
GTR 25 BB
1748 GTR Extreme
Fri Feb 17, 2017 3:17 pm
Thanks guys , so if I went cc rig 25 big block ,mods later. Smallest console I could find and nothing in rear and just big front deck . What size would yall choose on the hull
Fri Feb 17, 2017 3:18 pm
16x48 up to 17x50.
Id go 17x52 if you plan on mods anyways
Fri Feb 17, 2017 3:24 pm
A side console wouldn't be a bad option for more floor space in a boat that size.
Kool-Aid Brigade
www.southernfowler.com
Fri Feb 17, 2017 3:42 pm
Man I thought about a side console but I just don't really like the looks . I don't mind giving a small space up for comfort . How do you like your console rig compared to your old tiller . I know you can work a tiller better but I'm never in anything real serious moat of the time . Just shallow marsh
Fri Feb 17, 2017 4:06 pm
I went from tiller, to CC, back to tiller.
And I am definitely going back to CC or Stick steer.
Fri Feb 17, 2017 4:19 pm
I'll never go back to a tiller.
Unless its a long tail, or a small refuge boat.
Kool-Aid Brigade
Fri Feb 17, 2017 4:52 pm
My pops runs a 48" wide with a cc and theres plenty of room to move around . I'd go 17+ feet though. Short and skinny will be a turd with any kinda load.
Fri Feb 17, 2017 4:56 pm
Fri Feb 17, 2017 5:07 pm
Fri Feb 17, 2017 5:13 pm
The longer boat will do better than you think. Especially if you have any weight in the boat. Smaller boat may be slightly faster when empty, but it will be a turd when you start loading it down. The longer boat will have a better chance of still getting on plane and running at a decent pace.
Fri Feb 17, 2017 5:50 pm
