It is currently Fri Mar 20, 2026 4:37 pm
Reply to topic  [ 132 posts ]  Go to page Previous  1, 2, 3, 4  Next
 New beginnings
Post Re: New beginnings
You're rollin now.
Tue Apr 11, 2017 5:34 pm
Things are movin
"There's nothing a duck hunter hates more than another duck hunter."
Tue Apr 11, 2017 6:15 pm
Got the other catwalk framed... hope to have the rest of the front deck framed, and skin the catwalks and front deck with sheet metal tomorrow before I tie the back end up. Happy thus far, like the boats lines and it's very rigid. Only get better with the box strength of the catwalks sheet metal also with the sheet metal on the transom and rear end. More to come soon hopefully
Wed Apr 12, 2017 9:02 pm
how wide did you make the catwalks, and how much room is there between them?
Thu Apr 13, 2017 6:44 am
I tacked the tubing at 8" on the false transom and front deck brace, it stays at 8" about 60 percent of the way then it bumps out a little wider where the bow begins to pull in. As for the dimension between I don't know. I went with 8 because that will be about flush with where the floor meets the side. Be a nice place to sit on as well.
Thu Apr 13, 2017 7:38 am
Is that all TIG or are you using a wire gun as well? Very nice work.
Thu Apr 13, 2017 8:19 am
Push pull to this point I'm gunna heliarc the entire outside seams and as much visible welds as I can... thanks!
Thu Apr 13, 2017 9:28 am
No tig yet, all mig... wasn't very clear with the last post lol
Thu Apr 13, 2017 9:38 am
That boat is hell for stout, yah suure, you betcha. I was considering putting pictures of my new 18 X 60 build on here, but it's so flimsy in comparison I'm afraid I would be made fun of. That boat will certainly handle big water on the Mississippi. It should be great on the Rum and Snake also. Good job!
Thu Apr 13, 2017 12:11 pm
Thank you sir! Post em up! I feel like as many build threads to be seen as possible is a good thing, as it applies to helping others out with builds of their own!
Thu Apr 13, 2017 1:26 pm
Only got an hour to work this evening, got sheet metal on one of the catwalks... hoping for more time and progress tomorrow night
Thu Apr 13, 2017 8:12 pm
Do you know about what this rig will weigh? Hull only.
Thu Apr 13, 2017 8:22 pm
I'd say 4-5... sheet metal PO total weight was 260, plus the bracing, and sheet metal for the catwalks and front deck, as well as transom
Thu Apr 13, 2017 8:27 pm
Just did the math each brace accounts for roughly 20 pounds... so there's 400 between the sides and bottom, and 7 long braces alone.
Thu Apr 13, 2017 8:29 pm
Id say it would tip 500 all said and done. Around 900 with motor, gas, and battery.
Thu Apr 13, 2017 8:30 pm
Keep after it, maybe by the end of the weekend that sum birch will be ready to float. :D
Thu Apr 13, 2017 8:32 pm
That's really my goal... still waiting for my motor, but I've got a buddy with a gtr with heads, cam, and exhaust that we're gunna test the boat with... should cruise
Thu Apr 13, 2017 8:47 pm
You said you are in the south metro? Where abouts? I'm just in Chaska
Fri Apr 14, 2017 8:17 am
Right on! I live between prior Lake and lakeville... if you're familiar with horse and hunt I'm very close to that... Dohertys bar, etc
Fri Apr 14, 2017 9:14 am
I may be at the horse and hunt next weekend for the charity sporting clays shoot.
Fri Apr 14, 2017 4:12 pm
Joe BaronVon is right near by you as well, he is in New Prague.
Fri Apr 14, 2017 4:13 pm
Yeah I know Joe! We ought to all get together once the weather warms up for good and run the boats somewhere.
Fri Apr 14, 2017 4:25 pm
I'm in
Fri Apr 14, 2017 5:30 pm
I would like to say I'm in also, but I get worried that someone would take me into an area that my thin skinned boat couldn't handle and I would be in trouble. I'm west side in Rockford.
Fri Apr 14, 2017 7:38 pm
Sweet! Well if anything catastrophic were to happen, you'd have a handful of helpers.
Fri Apr 14, 2017 8:28 pm
Progress... don't think I'm done for the night but I have to take a breather and watch the rest of the wild game
Fri Apr 14, 2017 8:30 pm
with that outcome, you could have skipped the Wild game!
Fri Apr 14, 2017 8:58 pm
No kidding... close games though. Love playoff hockey
Fri Apr 14, 2017 10:36 pm
I'm really liking this boat. You are making fast progress too!
Sat Apr 15, 2017 6:16 am
Sat Apr 15, 2017 9:10 am
Are you going to weld your deck down, or screw it? I understand push pull, thats alot of trigger pullin.
Nice work again.
Sat Apr 15, 2017 9:48 am
Sat Apr 15, 2017 10:09 am
Use rivets.
Sat Apr 15, 2017 10:44 am
Sat Apr 15, 2017 10:47 am
Love the boat. It's a damn tank
Sat Apr 15, 2017 11:48 am
Thanks man!
I believe all the mig welding is complete... aside from bow eyes and grab handles which I have yet to order... now I just get to tig weld... which is always my easiest and favorite part
Sat Apr 15, 2017 12:11 pm
looking awesome! i was hoping to see a pic of the structure for the transom, and how you reinforced it.
Sat Apr 15, 2017 1:32 pm
Here ya go bubba... I used 2x4 .190 wall tubing for the main beams, and then 2x2 at an angle from the vertices to the center floor brace, and then one 2x2 straight across to the 2x2 brace across the back at the false transom. Rock solid and no flex... which is a huge component when you have a 300 pound motor shakin around back there and with bottom impacts and everything else.
Sat Apr 15, 2017 3:04 pm
Sat Apr 15, 2017 4:19 pm
Got er flipped over, just need to cut off the excess from the sides on the bow, and tig weld that outside seam and it should be sea worthy. Still need to install a plug, and put the bow eyes on, tie down spots on the rear (which in using weldable bow eyes for as well) and the grab handles... but it's close
Sun Apr 16, 2017 7:09 pm
