It is currently Thu Mar 19, 2026 12:27 pm
Reply to topic  [ 30 posts ]
 New boat build concerns
Post New boat build concerns
Im having a guy build a 17x48 with .125 mudboat. He used 2" sq. tubing ( front to rear ) every 7 1/2 inch center witch is good. My concern is he put 5 1/2 inch long x 2" sq tubing for bracing between every full length runners about every 6 inches. ( about 50 pieces )
My concerns are:
1) getting hooks in the bottom of the boat
2) extra weight
3) being to rigid ( no flex )
Are am I just being too paranoid???
Thanks for any impute.
Mon May 08, 2017 1:01 pm
Post Re: New boat build concerns
Brace across the top of the longitudinal bracing. By bracing in between it will end up looking like a washboard. Look at the bottom of a Beavertail Hull that has been run in the rough, you'll see what I mean.
Mon May 08, 2017 3:03 pm
You picked the wrong boat builder.
24x60 Dual Prodrives
Mon May 08, 2017 4:22 pm
I am thinking he means like a crossword puzzle style, 7 1/2" - 2" = 5 1/2"
I know Jack chit about boat building though, but that sounds like a solid hull
1244 Atchafalaya Outdoor Designs W/ 12hp Copperhead
2017 Atchafalaya Outdoor Designs 1244
2017 Copperhead 12hp
Mon May 08, 2017 6:38 pm
Tue May 09, 2017 7:13 am
I can just get the tips of my fingers under the cross bracing in mine.
I think I have only 4 or 5 not counting the storage compartments that run side to side.
And IMHO I would always get a better warm and fuzzy if the bottom is at least 3/16th(.190).
Tue May 09, 2017 8:17 am
2X1 welded in on the 1 inch side is better than 2X2s. Rectangled bracing is better than square.
Full disclosure: never built a boat or had a custom one built. Just done a little bit of reasearch and attention to detail on the infinite build threads here.
Shitty feeling if your getting this thing built and already having buyers remorse. I think the advice crews gave was pretty good, sell it as brand, take a small loss in the short run and start over doing it the right way. I may have never had a custom boat, but I damn sure have had some hooked boats and all these ghetto fixes (filling the hook) seem like a major pain in the ass and temporary at best.
Tue May 09, 2017 11:16 am
Sounds like a wash board bottom, when it gets hooked. I guess he meant well but did not know the proper building method for a boat hull. More does not always translate to better. Sucks for you, but you've gotten some good advice from Crews. Take it and use it.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Tue May 09, 2017 12:20 pm
how does all of that extra bracing cause more hooks? I'm not getting that....
Tue May 09, 2017 2:05 pm
For some reason ^ doesn't surprise me.
Tue May 09, 2017 2:15 pm
When u put any bracing sideways on the floor of a mudboat then slide over a stump it causes a hook right up to that bracing. All bracing that touches the floor should be longways down the length of the boat.
Tue May 09, 2017 2:18 pm
http://www.gatorglide.com/
gatorheads@comcast.net
Tue May 09, 2017 2:35 pm
-Custom pool noodle
-stage 4 water wings
Tue May 09, 2017 2:39 pm
speed bump reference, got it. good picture painted.
does the bottom of a hull not get dented with longitudinal stringers? guess that's my real question. I mean impacts are impacts, right?
Tue May 09, 2017 3:22 pm
Impacts are impacts and hooks are hooks. Impacts are not necessarily hooks, but hooks are caused from impacts.
Tue May 09, 2017 3:35 pm
Okay, I think I understand, the stiffness of the cross braced floor causes dimples like a golf ball, where as the longitudinal braces allow the dents to be spread out parallel to the direction the boat runs vs perpendicular to the direction.
Correct?
Tue May 09, 2017 3:49 pm
Tue May 09, 2017 4:46 pm
Wed May 10, 2017 8:56 am
all makes sense now!
Wed May 10, 2017 10:38 am
And in MOST applications, cross bracing in between the long runners isn't as rigid as one monolithic joint sat down across the top of the long runners and tied into the sides.
Wed May 10, 2017 12:08 pm
Well all is going to be good. I sent him pics before he even got started on the bracing and he didn't pay close attention. Knowing it was his mistake so he is going to start from scratch and get another broke out and build another. Thanks
Fri May 12, 2017 8:24 pm
Sat May 13, 2017 4:55 am
Sounds like a good guy.
Sat May 13, 2017 3:48 pm
Something along these lines will suffice...
Tue May 16, 2017 7:20 am
A mans boat i worked on. If you look real close you can see slight hooks at the rear bracing where the huntdeck starts
Wed May 17, 2017 8:37 am
Wed May 17, 2017 8:43 am
:lol:
Wed May 17, 2017 8:54 am
Am I missing something, I dont see the slight hooks anywhere........
:lol:
Wed May 17, 2017 11:11 am
It's to help the boat plane out
"There's nothing a duck hunter hates more than another duck hunter."
Wed May 17, 2017 12:50 pm
Wed May 17, 2017 5:11 pm
