It is currently Thu Mar 19, 2026 4:58 pm
Reply to topic  [ 77 posts ]  Go to page Previous  1, 2
 Building my own boat advice
Post Re: Building my own boat advice
It wasn't the welds. He would own it if it was.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Thu Jul 20, 2017 7:18 pm
Okay, but if the aluminum actually tore, then the boat was hugely lacking in structural integrity.
Thu Jul 20, 2017 7:43 pm
Ok.
Thu Jul 20, 2017 7:47 pm
My floor is welded....and just assuming it's still holding together. I'll let y'all know when I pressure wash all the hydroturf out of it! LOL
Thu Jul 20, 2017 7:54 pm
Thu Jul 20, 2017 7:56 pm
Thu Jul 20, 2017 8:00 pm
Right on, man. I meant no disrespect. As long as there is learning, then people are improving.
Thu Jul 20, 2017 8:04 pm
Thu Jul 20, 2017 8:24 pm
Fwiw, I'd love to hear an actual counter-point from Russ...
Thu Jul 20, 2017 8:32 pm
I did 1/2 inch holes welded on 6 inch spacing, and have already started going back and riveting sections because on hot days it makes noise when I walk on it. If you wanted it to be super stiff you could glue and rivet. That's how we did some racecar stuff that needed to be real strong.
1854 CC backyard build with GTR 37 EFI
Build thread here.. viewtopic.php?f=4&t=66815
Fri Jul 21, 2017 5:25 am
My welder was broke down for a couple days just got it back going
Thu Jul 27, 2017 6:16 pm
Looking familiar , pic from 1 phone to another, no the boat isnt bent
Thu Jul 27, 2017 6:57 pm
really coming along good!
Fri Jul 28, 2017 9:04 pm
If your going to weld the floor in, minimum 3/4" hole saw and run them on 12" centers. Done a ton of them this way and have never had a problem.
Would be a lot easier if you could get away with just using a 1/2" drill bit, but as North La said, most everybody I know that has tried that route has run into problems.
Mon Jul 31, 2017 1:47 pm
Does this look like enough bracing in the floor??? I'm wanting to try and weld the floor to the sides and then just rivet it to the longitudinal braces??
Sat Aug 12, 2017 11:37 am
I'd do a brace across the top of the longitudinal runners near the back and one in the front where your deck starts.
Sat Aug 12, 2017 11:52 am
Someone please correct me if I am wrong, but I think you would want a doubler on any cross braces that connects to the hull, like this. I do not know why it is done, but I suspect it helps prevent cracks.
2017 Atchafalaya Outdoor Designs 1244
2017 Copperhead 12hp
Sat Aug 12, 2017 1:22 pm
I don't like braces on top of the floor to b tripping over
Sat Aug 12, 2017 3:18 pm
I have some water leaks. Do you reckon some paint and gator glide will take care of them???
Sat Aug 12, 2017 3:27 pm
Nope, but a weld will....
-Custom pool noodle
-stage 4 water wings
Sat Aug 12, 2017 3:31 pm
Wed Aug 16, 2017 9:32 pm
Wed Aug 16, 2017 9:36 pm
Thu Aug 17, 2017 6:01 am
That brace looks good and then like north la hunter said, do one near the transom too.
Thu Aug 17, 2017 6:55 am
I just cant stand the thought of having a external brace right there in the way in the back. I'm probably going to skip it. Sounds like a good idea though
Thu Aug 17, 2017 7:27 am
Thu Aug 17, 2017 7:38 am
You should be able to brace the rear so that it's not in your way. Take a look at some of the other open layout boats on this forum. If you were gonna do a hunt deck like mine it would completely be out of the way.
Thu Aug 17, 2017 8:18 am
Thu Aug 24, 2017 10:37 pm
How did you bend the 1x2 rec tubing?
Thu Aug 31, 2017 8:26 pm
Fri Sep 01, 2017 1:21 pm
We took it out for first time Thursday. Only getting 3350-3400 rpm 26mph Mudbuddy is sending another prop and said I might need to change a gear to? If anybody's interested in buying my boat make offer and post your phone number here and I'll call you if it's high enough.[/img]
Sat Sep 16, 2017 4:40 pm
lol why are you selling it already?
You'd see better rpms and speed with a 2 blade prop.
That looks like a big 3 blade prop to me
Sat Sep 16, 2017 4:42 pm
It has a Black Death efi
yeah, that speed at those rpms don't exactly seem right either. 26 mph is typically a 3800+ rpm thing. What pitch is that prop? That's good speed for 3400 rpms.
#TheGhostBoat
Sat Sep 16, 2017 8:16 pm
Its a 12X11
Mon Sep 18, 2017 11:33 am
how did you bend that tubbing for the trailer
Sat Nov 25, 2017 6:45 pm
Mon Nov 27, 2017 9:17 am
