It is currently Fri Mar 20, 2026 4:37 pm
Reply to topic  [ 9 posts ]
 putting a deck type blind on my boat
Post putting a deck type blind on my boat
I have a 1960 Phowler I need a blind for, and I want to teach myself to weld aluminum. I think I am going to build a removable deck-type blind similar to that which the Gator Hide boats employ.
I am going to pick up 1 x 2 rectangular tubing for the deck frame tomorrow. How thick of sheeting should I be looking at to skin it?
This seems like a good project to learn on, but hopefully someone will chime in if it seems like a bad idea.
Sun Aug 13, 2017 3:06 pm
Post Re: putting a deck type blind on my boat
Doesn't sound like a bad idea but you'll probly need at least .100 if you're going to be walking around on top of it.
Sun Aug 13, 2017 3:53 pm
Wihat makes the hide great just isn't the deck. the rails are crucial as well as the poles welded into the deck. Do a little more research on them and you'll see.
GatorHide - MB
Sun Aug 13, 2017 7:26 pm
Yammer - I did this on a smaller boat but w/ wood when the GatorHide first came out to see how effective it would be. Worked well and I bought a 3 man and hunted it for 8 years. The issue for your boat is going to be laying out in boat and having the boat lean to the side you have 3-4 men hunting on if its in the water floating. The higher sides on your phowler may limit visibility - this would be avoided if you pull the boat on a mud flat or marsh. I would layout in the boat w/ 3 guys and see if the boat rolls to one side before you get into construction.
Mon Aug 14, 2017 11:29 am
Thank you for the heads up. I will check that out before I start cutting aluminum.
Mon Aug 14, 2017 11:46 am
Do the gatorhide boats lean also? Or is it something in their design that helps prevent it, other than width?
Wed Aug 16, 2017 10:10 am
Wed Aug 16, 2017 10:49 am
That would be easy enough to do on your own.
Wed Aug 16, 2017 11:03 am
GatorHide - MB
Wed Aug 16, 2017 4:46 pm
