It is currently Thu Mar 19, 2026 4:30 am
Reply to topic  [ 13 posts ]
 Boat don't run
Post Boat don't run
I have a 18x48 extreme metal fabrication hull with a stage one gtr 35 hp the boat doesn't run more than 25 by myself I was wondering on what size boats you guys are running and how they perform thanks
Thu Dec 14, 2017 9:41 pm
Post Re: Boat don't run
Sat Dec 16, 2017 5:39 am
What other factors you need ?
Sat Dec 16, 2017 4:23 pm
rpms, are you getting full throttle travel, weight of load, prop being used, diameter of prop, to name a few.
#TheGhostBoat
Sat Dec 16, 2017 5:11 pm
SMH
Sat Dec 16, 2017 5:13 pm
I'll add, some of the speeds you read online aren't exactly....accurate. 25 isn't right for a solo and light gear load, but depending on your load and the way your boat is built, 30+ may be wishful thinking.
#TheGhostBoat
Sat Dec 16, 2017 5:18 pm
New prop 4000 rpm I even tried adding some cup then took it off with just me at 185 lbs and 12 gal of fuel all I get is 25 two men 22-23
Sat Dec 16, 2017 10:02 pm
How long has it been since mods were done?
How does the bottom of your hull look?
Does the boat have any trim tabs that are bent down too much?
Have you checked your spark plugs lately?
Has the carb been tuned correctly?
Sun Dec 17, 2017 7:25 am
The boat didn't perform well since day one personally I think the sides have to much flare and the boat doesn't have enough rake plugs were just changed prop is good I'm debating weather to get a kip gaspard boat r a gator tail boat any suggestions?
Sun Dec 17, 2017 11:31 am
Sun Dec 17, 2017 1:08 pm
What kinda boats do y'all run and what kinda speeds do y'all get?
Mon Dec 18, 2017 10:08 pm
There were a lot of factors in your first question...
This second question has even more...
Mon Dec 18, 2017 11:07 pm
My buddies son in law has a built GTR on a 16ft tracker hull that runs 35mph when he has enough weight on the bow to keep it from hopping. Than damn boat will haul ass. I have a modded GTR on an 18 foot Alumitech that consistently runs 30-33 loaded and unloaded.
Tue Dec 19, 2017 7:10 am
cron
