It is currently Mon Mar 16, 2026 3:21 pm
Reply to topic  [ 23 posts ]
 16x56 GoDevil Makeover
Post 16x56 GoDevil Makeover
Well guys,
I started a complete makeover of my boat. I have to move some weight around bacause I can't run my boat by myself. The boat was porpusing too bad. I had previously cut my bow open to install 2 6 gallon fuel tanks under there. Well, that helped until I starting modding the motor. So now, the new project has begin. Under the bow where the fuel tanks were, I'm mounting my dual batteries and a 2 bank on board charger. I'm having a new 12 gallon fuel tank built. The tank is going to be at the end of the deck. Its 6" tall, so I'll be able to use it as a step to get onto the deck. And while I'm doing all of this, I'm rewiring the entire boat. Going to move my switch panel to make it a little more accessible. The only real weight I'm adding is the 2 bank charger and the weight of the aluminum tank. I already had 2 batteries. One at the transom and one at the bow. Hopefully getting the battery out of the back will fix my problem.
Here is a pic of the old gas tank setup.
I'll attach more pics as the project goes on. That is if anyone is interested.
Thu Jul 30, 2009 10:27 am
Post Re: 16x56 GoDevil Makeover
Post some more pics of that light set up you got
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Thu Jul 30, 2009 10:32 am
I have more pics of the light rack posted in the photos section. I think the title of that post is new guy here, just some pics of my rig.
Thu Jul 30, 2009 10:45 am
Between the crappy weather and work, I finally got the rewiring part of this project finished this morning. I moved the battery from the back of the boat to under the bow. Also installed my spare/trolling motor battery under the other side of the bow. You can't see form the pics, but mounted in front of the 2 batteries is a Minn Kota 2 bank battery charger. I mounted the plug thru the deck. Makes it easy to just plug in the extension cord every time I put her back in the shed.. I ran my battery cables thru the ribs up to the bow. Then I ran a new power and ground feed thru another rib and punched a hole into the drivers side storage box. I mounted a distrubution block to the wall of the storage box. Then made all my connections to that. I also moved my switch panel. The previous owner had the switch panel mounted under the GPS. That location made it difficult to see at night. The new location will be much easier to see.
I'm waiting for the fab shop to call me so I can bring the boat over there for final measurements for the custom gas tank. Here are some pics of the finished electrical project.
Mon Aug 03, 2009 1:54 pm
Looks good the gas tank didn't work out?
18X54 Center Console GTB/GTR35(lil daddy mods)
http://community.webshots.com/user/blaze715
Mon Aug 03, 2009 5:09 pm
No, turns out I'm not going to use it. Found someone to build me a custom tank. Its gonna be the width of the floor. 10 inches deep and 6 inches tall. Its gonna be a step to get onto the bow. Thats the route i wanted to go in the first place. Hopefully, it'll be finished this week.
Mon Aug 03, 2009 8:05 pm
Looks very "tight" and functional...
Like the distribution block, is it fused....
Where did ya get it ???
Eat - Sleep - Hunt ! ! !
Mon Aug 03, 2009 8:23 pm
Looks good!
1754 GT w/ 35 GTR Hoytafied
Mon Aug 03, 2009 8:32 pm
cuz it cam out nice we work hard.....well u worked the hardest lol on it be u got it
Mon Aug 03, 2009 8:36 pm
Profile YIM
The boat does look dam good. Always worth the time you put into it.
Mon Aug 03, 2009 8:43 pm
The distribution block is not fused. I placed an in-line fuse between each connection in the block and the switch. The distribution block is made by Blue Sea Systems. I got it from a local boating supply house.
Mon Aug 03, 2009 9:03 pm
New fuel tank is finished. Put it in the boat today for a test fit. I'm happy with it. Gotta get me some aluminum angle to mount it. Gonna try to get some paint on it this week. Here are some pics I took when I put it in the boat today. I'll try to get some better ones soon.
Fri Aug 14, 2009 6:24 pm
looks good
Fri Aug 14, 2009 6:32 pm
Profile YIM
Man boat looks good... Got a ? what was the best way to get all the foam out of the bow? I just cut mine and have been working on it.... Its a pain in the near to get the foam out.
16 X 60 GDSD W/ A 35
Thu Aug 20, 2009 7:32 am
I got in the bow with a razor knife. Cut chunks of foam and pulled till it came out. No real trick to it. Also, I know that an electric filet knife works really well for cutting the foam.
Thu Aug 20, 2009 1:15 pm
Nice looking rig fo sho. I want to see it when the gas tank is fully installed
Fri Aug 21, 2009 2:42 pm
Finally got the tank installed this weekend. Tell me what ya'll think.
Mon Aug 24, 2009 8:07 pm
Nice....
Those dual batteries will be great for night opps with lights
and extended fishing / runtime with the trolling motor....
She ought to balance out nice on solo runs now too....
Mon Aug 24, 2009 8:46 pm
She is getting better. Haven't ran solo with the tank yet. But with the batteries up there I'd get about 27 or so before the porpusing would start. Way better than the 21 i would get before. Hopefully I'll get a chance to run solo soon. I think with just a little adjustment of the tabs on the motor I'll be set.
Mon Aug 24, 2009 9:17 pm
Is your floor rhinolined?
Tue Aug 25, 2009 7:20 am
Actually, its Herculiner. This was my first time putting this stuff down, so I didn't really know what I was doing. I also had about 4 gallons of gas spill and sit on the floor of the boat for about 2 weeks. The fuel line on my generator busted and drained onto the floor. I was out of town and didn't catch it for a while. The rest of the floor is holding up really well. Now that I've done a few more bedliners with this stuff I'm gonna redo the boat. Better prepwork makes it hold up great!
Tue Aug 25, 2009 7:41 am
I did the Herculiner in mine, holdin' up good, except it shrank a little, so you can see some specks of aluminum where I didn't go heavy enough. I used my sandblasting gun to spray it, just stabbed a hole in the top of the Herculiner can and stuck the siphon in. You better move though, it'll dump a gallon out in no time. I wann do something like that with my gas tank too, put it under the bow with a fill neck coming out.
Put yer face in the myrtles.
Sat Aug 29, 2009 7:37 pm
I am looking to do some mods to my 16x44 GoDevil boat as well but can't find many pictures of other boats with mods. Anyone got any pictures.? For some reason i can't see the pictures in this thread.
Go Devil 16x44 with 35hp GD
Fri May 11, 2018 7:48 am
